A10 with no power
  • A340
    • Sep 2019
    • 6
    A10 with no power
    A10 with no power
    Why there is no power to the Admiral 6ch Gyro Stabilizer after both batteries are connected to the ESCs of the A10 EDF?
    • 5426
    Is everything plugged in that's supposed to be? What have you not plugged in? Is the BEC plugged in?
    • A340
      • Sep 2019
      • 6
      Hi, yes everything is connected, the UBEC is also connected to the spare channel, the only thing that I made different it was that I connected a 4.8v battery to set up all the moving surfaces to the correct high/low rates.
        • 5426
        Can you put a meter on the UBEC and make sure it's putting out power? Should be 5.0VDC.
        • A340
          • Sep 2019
          • 6
          I already done and nothing, there is no information on the meter!
            • 5426
            I think that is your answer. Did you plug the 4.8V battery and the BEC in at the same time?
            • A340
              • Sep 2019
              • 6
              Yes I did.
                • 5426
                You may have burned out the BEC...
                • A340
                  • Sep 2019
                  • 6
                  Well, that is no good news! Anyway, thank you for all your help. I really appreciate it.
                  Thank you
