Jet designs you would like to see produced
  • spook
    • Jun 2019
    • 15
    • Germany
    B1B and Fouga Magister
    • GarrisonR
      • Jul 2019
      • 56
      • La Mesa, CA
      Not to send you guys down a youtube rabbit hole, but man that would be awesome and quite the challenge. This guy is attempting this, very scale and using two edf units. I also included a link to the high wing trainer version he has actually made flights on. The F35 so far has only seen hovering.
      Trainer full transition flight:
      Either a Harrier or F-35... I think with the engineering FW/ FL is capable of they should do an Osprey too. A good size one, 1500mm or so .
      • cg7060
        • Jun 2018
        • 24
        F-117A Nighthawk
        • T- Elbert
          • Sep 2020
          • 98
          • Helena, Montana
          F-8 crusader 90 mm
          F-105 thud. 90 mm
            • 8228
            SR-71
            B-1
            B-2
            F-117
            • SanExup
              • 912
              • Western Wy.
              That F117 sure shows up a lot in posts.
              • kevin
                Jet / Warbird pilot
                • Mar 2014
                • 21
                • Dublin Ohio
                Learjet 35A / C-21A
                • Steam28
                  • Jan 2021
                  • 2
                  F-100D Super Sabre
                  • Guy Ricken
                    Guy Ricken
                    • Jan 2021
                    • 5
                    • Amsterdam, The Netherlands
                    Hawker Hunter 👌🏼
                    • Dapreacherman43
                      • Jul 2019
                      • 6
                      T-38 tbird
                      t-37
                      f106 delta dart
                      douglas f4d skyray
                      • kallend
                        • 1877
                        • bandetx
                          • Nov 2017
                          • 88
                          I don't think they are quite there yet to make a f-35.
                          I remember a year or two ago some chinese company made a f-35 that would vtol and transition, but like it was eps, fixed gear, no rudder or ailerons the entire thing was tailerons because of weight.
                            • 5401
                            I want a proper one with all the stuff like retracts and flaps if the original had it. Plus a decent size, at least the size of current FW 80mm jets. A Harrier would be great.
                            • wolpertinger
                              Pilot ??
                              • 313
                              • Earth
                              Waiting on the F9F Cougar or Panther in a 80mm or 90mm or a twin 80MM F15 to play with my Mig 29. Although a twin 80mm YF23 with TV would be great to. Any of these get added to my hangar.
                              • slumi
                                • Apr 2020
                                • 54
                                • Luxembourg
                                The Vulcan delta jet bomber.
                                Also interesting is the very first jet before the Me 262, the Heinkel He 162.
                                • slumi
                                  • Apr 2020
                                  • 54
                                  • Luxembourg
                                  I was mistaken. The very first jet was Heinkel He 178 and had it’s first flight in 1939. The He 162 was the last simplified jet fighter in 1945 and only saw limited action.
                                  • mongo
                                    BFMA #13
                                    • Aug 2018
                                    • 38
                                    • midland, Texas
                                    real twins:
                                    2x 80 mm F-4
                                    2x 80 mm T-38
                                    2x 80 mm F-101
                                    80 or 90 mm F-106
                                    when they outlaw R/C, only outlaws will have R/C
                                    • Dwalkerp47
                                      Dew-Man
                                      • Jun 2018
                                      • 31
                                      • Euless, Texas
                                      B-58 Hustler
                                      • uscanuck1xa
                                        • 100
                                        • Memphis, TN
                                        Likely doesn't have wide enough appeal but I would like to see a CT-114 Tutor. A Canadian air icon! Preferably in this livery!
                                          • 5401
                                          Interesting, I had to look that up since it looked similar to the Cessna..
