Where to plug UBEC into receiver ON 8s f22 raptor?
  • az1954az
    • Oct 2020
    Building a Freewing f22 8s Raptor! Where is the UBEC supposed to be plugged into receiver? I have received several answers and now confused!! Help needed from the pros!!
  • RRHandy
    Instructor Pilot
    • 892
    • Lilburn GA
    You can Y any of the channels and plug it in, if the bind port is open, plug there.
    AMA 424553
    • Gilatrout
      RC Pilot Addict
      • 806
      • Albuquerque NM
      The only caveat to using the bind port is that some of the newer spektrum receivers will go into bind mode when powered. Therefore if you are always going into bind mode, y the Bec into a different port
      • RRHandy
        Instructor Pilot
        • 892
        • Lilburn GA
        That's a new one for me.
        AMA 424553
        • RRHandy
          Instructor Pilot
          • 892
          • Lilburn GA
          I have not found any info saying that.
          AMA 424553
          • Gilatrout
            RC Pilot Addict
            • 806
            • Albuquerque NM
            This is from personal experience with at least the ar637t. Plugging a Bec into the bind port caused the receiver to go into bind mode everytime it was powered.
            In fact, if you look at the port, it is no longer labeled batt.
            • RRHandy
              Instructor Pilot
              • 892
              • Lilburn GA
              It's funny that info is not even in the manual.
              AMA 424553
              • Av8er278
                • Jan 2021
                • 123
                • San Diego, Ca
                I just built my F22 and I have a 6ch receiver and I plugged it in the bind plug and no problems. Motion RC told me just plug throttle in throttle port and bec in any other port with bind plug in bind port after that plug all your servos in and bec to bind port.
