Where to plug UBEC into receiver ON 8s f22 raptor?
  • Where to plug UBEC into receiver ON 8s f22 raptor?
    Building a Freewing f22 8s Raptor! Where is the UBEC supposed to be plugged into receiver? I have received several answers and now confused!! Help needed from the pros!!
    You can Y any of the channels and plug it in, if the bind port is open, plug there.
    AMA 424553
      The only caveat to using the bind port is that some of the newer spektrum receivers will go into bind mode when powered. Therefore if you are always going into bind mode, y the Bec into a different port
        That's a new one for me.
        AMA 424553
          I have not found any info saying that.
          AMA 424553
            This is from personal experience with at least the ar637t. Plugging a Bec into the bind port caused the receiver to go into bind mode everytime it was powered.
            In fact, if you look at the port, it is no longer labeled batt.
              It's funny that info is not even in the manual.
              AMA 424553
                I just built my F22 and I have a 6ch receiver and I plugged it in the bind plug and no problems. Motion RC told me just plug throttle in throttle port and bec in any other port with bind plug in bind port after that plug all your servos in and bec to bind port.
