Avanti s LED light replacement.
  • Tomling31
    • Nov 2021
    • 22
    Hello everyone, a quick question, I’d like to fit some Unilights to replace the standard lights. Does anyone know what wattage or power the current wing lights are in the Avanti. I think I could fit 4w lights in the wings but I just wondered what the standard ones are to make sure It’s noticeably brighter for the money to make it worth it.
    Many thanks.
    Tom.
    • 5426
    Stock are 1W. Remember that the circuit board cuts the voltage to about 3V that the LED uses.
    • kallend
      • 1877
      While I haven't actually pulled the board apart, I believe its simply a current limiting resistor in there.. Different color LEDS need different voltages.
      https://qph.fs.quoracdn.net/main-qim...3e6fb0f02e9c89
      IF that is correct, then putting in a higher powered LED but using the same supply from the board won't help much, since the limiting factor will be the current.
        • 5426
        It is a resistor.
        • Tomling31
          • Nov 2021
          • 22
          Thank you for the reply’s. I couldn’t find the figure anywhere. Will replace with 4/6w so it should be a good improvement, I will use the Unilight power board and bypass the normal one. Thanks guys for the help.
          • kallend
            • 1877
            Yes, you need to change the power board too or won't get much improvement.
            • Tomling31
              • Nov 2021
              • 22
              Thanks mate, it would be a totally separate unit bypassing the Freewing board.
              • valke011
                • Sep 2022
                Which lights from unilight did you use?
