Freewing Gripen vs Mirage vs Eflite F16
  • kallend
    • 1871
    Originally posted by Philipp_TSG
    Well its a tough decision. I dont really want to get any other EDF in it than the stock one. I heart that the Gripen is very underpowered with the TV. Is the power enough to have some fun flying fast low passes and high alpha? Or is that only possible with the 8s setup?
    I put the 6S FMS 2100kV "PRO" in mine, and it is by no means underpowered.
    If you want top speed and climb on a stock model, get the Mirage 2000.
    • Philipp_TSG
      • Apr 2020
      • 11
      Just ordered the Gripen😍😍
      • Husafreak
        • Dec 2018
        • 125
        • NorCal
        Hey glad to hear it. You will enjoy it still with the stock fan, if you have a light battery it will do the high alpha and everything flying wise well. It just won't "punch out" of slow flight or hold a hover. You will have to lower the nose and gain flying speed to transition to fast flight. Note that if you have issues with the gear doors staying open then you are going to fast at retraction. Maybe not a problem but if it is then I suggest after you take off climb a bit and slow (I pull straight up into a hammerhead stall) and hit the gear switch, it will retract fine at slower speeds. Cheers!
