Avanti sport jet motor problem
  • MarkdaleMark
    • Jul 2022
    • 4
    New to this forum so excuse me if this topic has been covered. I have the free wing 80mm edf avanti sport jet. I’m using an admiral 6000 mah 50C battery. When I plug the battery in all control surfaces work but I’m getting a rapid beeping and no motor response. I’m thinking there is something wrong with my esc but being relatively new to electric flight I wanted to get some opinions. Thanks in advance
  • kallend
    • 1877
    ESC won't arm unless the throttle is closed.
    1. maybe your throttle stick needs calibrating. Does your transmitter have a stick calibration routine? Does it have a monitor to see what the channel output is?
    2. maybe your throttle trim is set too high,
    3. Maybe the ESC needs calibrating.
    • MarkdaleMark
      • Jul 2022
      • 4
      Thank you for this. Between the last time I flew it abs this problem I was monkeying around with the throttle trim setting. I will take a look
        • 8835
        Also check all 3 ESC to motor wires to ensure all are connected solidly and no wires/connectors are damaged.
        • MarkdaleMark
          • Jul 2022
          • 4
          Thanks to everyone. The throttle trim was not at zero. Problem solved
