Freewing Banshee 64mm Sport EDF Jet
Click image for larger version  Name:	10.jpg Views:	14 Size:	47.0 KB ID:	356348
The Freewing Banshee 64mm EDF Jet is the perfect introductory model for those seeking to break into the thrilling world of foam Electric-Ducted Fan jets. Made with industry-standard and durable EPO foam, the Banshee comes with a 12-blade EDF with a robust 2836-3300Kv inrunner brushless motor for captivating aerial adventures.
The Banshee's streamlined shape penetrates through the skies with minimal resistance while the 4s power system delivers an exhilarating thrust-to-weight ratio. The Banshee’s modular structural design uses plastic joints and screws to facilitate simple assembly, maintenance, and repair, a welcomed departure from the tedious and adhesive assembly of models from years past.
Enjoy the Banshee’s low wing loading for increased performance at lower speeds. With the installed flaps the jet can handle slower landings and shorter takeoffs with ease. The ESC has a reverse thrust function that slows the jet upon landing, dramatically reducing the landing rollout. If you do not wish to utilize the fixed landing gear, the Banshee excels as a capable hand-tosser/belly lander. Take to the skies with this excellent jet that both novice and experienced pilots alike will equally enjoy.
Features:
  • 40 Amp V2 Electronic Speed Control with reverse thrust functionality
  • Flaps are included for slower flight, landings and quicker takeoffs
  • Comes with 12-Blade EDF with 2836-3300Kv Inrunner Brushless Motor
  • 4S LiPo capability for High Performance Flight (not included)
  • Scale details including painted pilot and cockpit, panel lines and landing gear
  • 8x 9g digital servos come pre-installed
Includes:
  • Freewing Banshee 64mm Sport EDF Jet - PNP
  • Servos, motor, fan unit and ESC are all pre-installed
Requires:
  • 4 Channel Radio - Select a minimum 4 channel radio from our Radio Collection
  • 4 Channel Receiver - Select a minimum 4 channel receiver from our Receiver Collection
  • 4 Cell 14.8V 1800-2600 mAh LiPo Battery with XT60 Connector - EPR22004PROX6
  • 4 Cell Compatible Battery Charger - Select a minimum 4 cell (4S) charger from our Charger Collection
