eFlite 80mm F-16 T-Bird
  • Lateral-G
    • Sep 2022
    • 23
    Just arrived today. Less than 24hrs from placing the order at Tower to my bench. Add 2 hours to assemble and set up the radio.
    Charging my 6s 6000 and 6250 packs for potential maiden tomorrow.
    Wish me luck.
    • 5426
    Good luck with the maiden!
    • Lateral-G
      • Sep 2022
      • 23
      Beautiful day for a maiden flight. Living my life 3.5min at a time.
      Used a Hoovo 6250mAh 6s pack. Landed after 4 solid minutes with 44% left. First landing was not the best but that was on me. By the third flight I got it sussed. The telemetry said max altitude was 367ft. Seemed higher...
      Only issue was a bit of wing waggle on the roll axis. I need to turn down the gain. I was in AS3X for all my flights. Didn't use SAFE.
      Landings seemed better at 1/2 flap for some reason.
      I programmed thrust reverse so it went full when switch G on my NX8 was pulled full aft. Helped on landing rollout.
      Looked so damn good in that blue sky. But when head on at a distance it can disappear on you.
        • 5426
        Congrats! Nice pics too.
        • kallend
          • 1877
          Originally posted by Lateral-G
          [FONT=inherit]
          The "low visibility grey" schemes are worse.
          • jasmith41
            EDF-obsessed
            • Sep 2021
            • 317
            • AZ and NE Ohio
            i have the gray version and it's one of my favs... was afraid of this bird at first so i started with the 70mm and it was so easy to fly that i pretty much immediately went out and got the 80mm gray version and gave the 70mm TB to my buddy...
            • edwardyn
              • Aug 2021
              • 6
              Good luck to you.
