Freewing afterburner on viper 90mm instead of lighting the leds it cuts throttle completely off at 40% throttle up all hooked up correctly as far as I can see any similar stories or suggestions
Freewing afterburner on eflight 90mm viper
Mine doesn’t do that though it does come around that percentage throttle setting. Might I suggest disconnecting the afterburner and see if the throttle still cuts out at 40%. If it does then eliminate the control board and fly without an afterburner. If it is the control board I’d say direct connect everything to your RX, that board could be bad. Hate to hear you lost your bird.
Rich
Which receiver and ESC? If a SMART receiver and an Avian ESC, you will have problems.Comment
I had to look up the "fctory electronics" since you didn't answer the question. It's an AR637TA receiver.
Try plugging the Avian into the leftmost slot on the receiver, labeled "Bind/prog/srlx2". It should work fine there and the afterburner should remain in slot 1 and work OK too.
You will still run into issues with the afterburner turning on too soon - see my other thread on the subject.
Incidentally, it's only the Avian ESC that does this. It doesn't play nicely with anything else plugged into slot 1.Comment
I had to look up the "factory electronics" since you didn't answer the question. It's an AR637TA receiver.
You're welcome.
As a rule, if you are asking for assistance with a technical issue, the more information you provide the easier it is for someone to help you.Comment
Kallend, any idea what's going on here? I updated and factory reset some AR637TAs and then when i unplug them from the power and try to power them back up, I'm getting nothing out of them - they won't power up, bind, or even go into bind mode...
Not sure what i'm doing wrong... I'm using a 3s for power into the bind port / channel (and i've tried other ports / channels as well), and I set up an 'RX Programming" model in my IX20 to update, unlock and reset these extra receivers...
I'm stumped. Any thoughts?Comment
637T Type DSM2/DSMX 6 CH AS3X Telemetry Receiver Application Air Channels 6 Receivers 1 Remote Receiver (not included) SRXL2™ Remote Receiver Optional [SPM9747, SPM4651T] Modulation DSM2/DSMX Telemetry Integrated Bind Method Bind Button, Bind Plug Failsafe Yes Band 2.4GHz Dimensions (LxWxH) 49.80 x 23.34 x 15.02mm Weight 12g Input Voltage 3.5–9V Resolution 2048 Antenna Length 155mm and 186mm SComment
