Eurofighter Typhoon 90MM 6S PNP Power Issues...
  • Mythic768
    • Nov 2023
    • 4
    I don't have a ton of experience with EDFs but I own a Freewing Mirage and that thing is awesome so I decided to get the Eurofighter.. Maiden flight it felt very underpowered and shrugged it off as I used an old battery. Put brand new 120C battery in it and recalibrated the esc and still the same thing.. It has zero vertical climb ability.. it falls out almost immediately. Full throttle is around 67mph. I don't really know what the issue could be. The motor doesn't feel hot or anything. Anyone have any suggestions?
    • 5426
    Put a wattmeter on it.
    • stampfield
      • Mar 2023
      I would verify that you have the 6s motor. 3668-1960kv your performance is so low ( 63mph) sounds like maybe you have the 8s 1350kv motor?
      • Mythic768
        • Nov 2023
        • 4
        Yeah, I thought that too but checked out the motor and its 3668-1960kv
        • Mythic768
          • Nov 2023
          • 4
          What watts should it be reading at full throttle?
            • 5426
            About 115A and 2400W.
            • Mythic768
              • Nov 2023
              • 4
              Thank you, I don't own a watt meter but ordered one. I'll let you know the results!
