Official Black Horse 1720mm L-39 Albatros Turbine Jet ARF Thread
    L-39 Albatros Turbine 1720mm (67.7") Wingspan from Black Horse - Balsa Wood ARF - BHM1014-001
    The Aero L-39 Albatros, developed by Aero Vodochody of Czechoslovakia, is a highly-capable jet trainer. It is now the world's most widely-used jet trainer, not only for basic and complex pilot training, but also for light-attack missions. Making its first flight in November 1968, it was the first trainer plane to be equipped with a turbofan engine.
    The Black Horse L-39 Albatros is a 1720mm wingspan ARF ready to install your turbine power system with up to 8kg of thrust (not included). Built durably with balsa and plywood construction, the L-39 comes pre-covered in heat-shrink film with pre-printed graphics simulating panel lines, rivets and livery detail.
    Factory Weathered Printing
    The printing on this model has a realistic weathering complete with rivet and panel line detail that elevates the model to a whole new level of scale appeal.
    Generous Scale Detail
    The L-39 comes with loads of scale appeal such as a highly detailed cockpit including painted pilot, ejection seats and gauges.
    Turbine Power
    This model is designed for turbine power. Comes ready to install your turbine power system with up to 8kg of thrust (not included).
    Electric Retract Gear with Oleo Struts
    The electric retractable gear with oleo struts adds extra scale appeal and realism to the model.
    • Lightweight, strong, laser cut balsa and plywood construction
    • Electric retract gear with oleo struts and control box
    • Panel lines and details printed directly onto the pre-applied, high quality covering
    • Airfoiled tail surfaces
    • Recessed hinges on all control surfaces
    • Pre-cut hinge slots
    • Heavy-duty CA hinges on all control surfaces
    • Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass control horns
    • Comprehensive control and fitting accessories included
    • Two-piece, plug-in wings simplify transportation and assembly
    • Black Horse L-39 Albatros Turbine 1720mm (67.7") Wingspan - ARF
    • Control box
    • Owner's manual
    Requires:Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1:8 Scale
    Wingspan 1720mm / 67.7in
    Length 2163mm / 85in
    Weight 9600g / 21lbs
    CG (Center of Gravity) Refer to the manual
    Wing Area 60.7 dm2
    Wing Loading 158g/dm2
    Power System 60N turbine system (required)
    Electronic Speed Control N/A
    Propeller / EDF 60N turbine system (required)
    Servos 8x 45g standard (required) - we recommend HRC32645S
    Landing Gear Electric retract gear with oleo struts (included)
    Required Battery 2x 2S 7.4V LiPo 2200mAh - 3200mAh Receiver Batteries (required)
    Required Radio 10+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Optional
    Hinge Type Heavy-duty CA
    Material Balsa and plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • Laury415
    • 14
    Interested, anyone have this jet?
    • SparrowHawkLab
      • Mar 2021
      Would an EDF conversion be possible? Like a 120mm?
      • hcew
        • Nov 2020
        • 10
        Hello,
        I have one and due to weather only one flight.
        Use a JetsMunt 80BL.
        The Albatros is a very good Model, but the landinggear is waste.
        I'm just change it in one from JP-Hobby.
        • Scale330l
          • Apr 2023
          Does it use all standard servos or what servos are needed? The Viper said all standard but ended up needing smaller servos in elevators and rudder if I remember correctly.
          • bigd5963
            • Jul 2022
            • 12
            They both take mini servo's through out the whole jet. No standard servo will work unless you modify the main wing servo tray. Don't know why Motion has not changed that.
            • mavdriver
              • 38
              • Hesperia , California
              Originally posted by hcew
              Hello,
              Hi what JP landing gear did you use another words is there a specific model number ?
              • hcew
                • Nov 2020
                • 10
                Hi,
                it is the same gear as for the green Viper.
                But the mounting holes do not match. But this is no prblem to drill new.
                • Laury415
                  • 14
                  I just got this check. I was wondering what size turbines people are putting in? It calls for an 80 kg, but that seems a little small
                  • mavdriver
                    • 38
                    80 turbine will work just fine but a 100 will make this bird move
                    • Steepdiver
                      • Mar 2025
                      I was looking at this model, and as much as I love turbines, the flying season for them were i am is too short with burn bans.
                      Is an EDF conversation on this model possible? And if so what is the largest fan unit that could be placed into this model? I have looked and can get 21lbs of thrust from a 110mm fan unit on 12S. I bwlive thats just under what 100N turbine would produce.
