The Aero L-39 Albatros, developed by Aero Vodochody of Czechoslovakia, is a highly-capable jet trainer. It is now the world's most widely-used jet trainer, not only for basic and complex pilot training, but also for light-attack missions. Making its first flight in November 1968, it was the first trainer plane to be equipped with a turbofan engine.
The Black Horse L-39 Albatros is a 1720mm wingspan ARF ready to install your turbine power system with up to 8kg of thrust (not included). Built durably with balsa and plywood construction, the L-39 comes pre-covered in heat-shrink film with pre-printed graphics simulating panel lines, rivets and livery detail.
Factory Weathered Printing The printing on this model has a realistic weathering complete with rivet and panel line detail that elevates the model to a whole new level of scale appeal. |
Generous Scale Detail The L-39 comes with loads of scale appeal such as a highly detailed cockpit including painted pilot, ejection seats and gauges. |
Turbine Power This model is designed for turbine power. Comes ready to install your turbine power system with up to 8kg of thrust (not included). |
Electric Retract Gear with Oleo Struts The electric retractable gear with oleo struts adds extra scale appeal and realism to the model. |
- High level of prefabrication right out of the box
- Lightweight, strong, laser cut balsa and plywood construction
- Electric retract gear with oleo struts and control box
- Panel lines and details printed directly onto the pre-applied, high quality covering
- Airfoiled tail surfaces
- Recessed hinges on all control surfaces
- Pre-cut hinge slots
- Heavy-duty CA hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed cockpit, pilot and interior included
- Fiberglass control horns
- Comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly
- Black Horse L-39 Albatros Turbine 1720mm (67.7") Wingspan - ARF
- Control box
- Owner's manual
- 10 Channel radio - select a minimum 10 channel radio from our Radio Collection
- 10 Channel receiver - select a minimum 10 channel receiver from our Receiver Collection
- 60N or greater turbine power system (6.4kg of thrust or more)
- 8x High Voltage High Torque servos - we recommend Hitec D-645MW High Voltage High Torque Digital Metal Gear Servo Airplane Multi-Pack (8 Servos)
- 2x 2 Cell 7.4V 2200 - 3200mAh LiPo batteries for battery receiver
- 2 Cell compatible battery charger - select a minimum 2 cell (2S) charger from our Charger Collection
Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :6+ hours
| Model Scale | 1:8 Scale |
| Wingspan | 1720mm / 67.7in |
| Length | 2163mm / 85in |
| Weight | 9600g / 21lbs |
| CG (Center of Gravity) | Refer to the manual |
| Wing Area | 60.7 dm2 |
| Wing Loading | 158g/dm2 |
| Power System | 60N turbine system (required) |
| Electronic Speed Control | N/A |
| Propeller / EDF | 60N turbine system (required) |
| Servos | 8x 45g standard (required) - we recommend HRC32645S |
| Landing Gear | Electric retract gear with oleo struts (included) |
| Required Battery | 2x 2S 7.4V LiPo 2200mAh - 3200mAh Receiver Batteries (required) |
| Required Radio | 10+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | Optional |
| Hinge Type | Heavy-duty CA |
| Material | Balsa and plywood |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
