90mm F8 Crusader (scratch built)
  • T- Elbert
    • Sep 2020
    • 98
    • Helena, Montana
    Me and a few buddies have been discussing EDF’s we would like to see (like everyone else) and several always come up. The crusader is always high on the list , imagine my surprise when Julius Perdana tossed out a video on one. After looking at his plans I got out the trusty slide ruleand rescaled them to 90%.
    wingspan 40”
    length. 56”
    all motion gear was used
    90mm 3668-1960kv 12 blade fan
    120 amp thrust reversing speed controller
    4 17gram servos
    2 9 gram servos
    F9F cougar front gear
    90mm F16 main gear
    Old A4 decals I had laying around
    This is a proof of concept airframe, I realize it is not true to scale but it is close and the Mark II versio willl rectify this. Working with depron is new to me ( always a learning curve) but I have seen nice results by Chris Wolf and others.
  • T- Elbert
    • Sep 2020
    • 98
    • Helena, Montana
ID:	401928 Click image for larger version
ID:	401929 Click image for larger version
ID:	401930 Click image for larger version
ID:	401925 Click image for larger version
ID:	401926 Click image for larger version
ID:	401927 Click image for larger version
ID:	401924 Click image for larger version
ID:	401923 Assemble and engineering
    • T- Elbert
      • Sep 2020
      • 98
      • Helena, Montana
ID:	401933 Click image for larger version
ID:	401932 Click image for larger version
ID:	401934 Click image for larger version
ID:	401937 Quick paint and decals
      • T- Elbert
        • Sep 2020
        • 98
        • Helena, Montana
ID:	401941 Click image for larger version
ID:	401942 Click image for larger version
ID:	401939 And finally Click image for larger version
        • T- Elbert
          • Sep 2020
          • 98
          • Helena, Montana
          I have 6 flights in on it, a bit tail heavy on the maiden, had to add 1oz to the nose. Weight is 5.9 pounds, a little fragile but has good speed ,lands nice, needs cheater holes at slower speeds to allow a faster spool up.
          • NewbieBob
            Back at it
            • Sep 2022
            • 83
            • Eastern Ontario
            WOW. BEAUTIFUL SCRATCH BUILD.
            KUDOS TO YOU SIR.
            • quitcherbitchen
              • 927
              • Altadena, CA
              Very nice. More ;pictures please
              • T- Elbert
                • Sep 2020
                • 98
                • Helena, Montana
                I will get more flight pictures on my next outing to the field. Are there any pictures you would like?
                • SanExup
                  • 912
                  • Western Wy.
                  T- Elbert Looks badass Travis! Nice work on both the build and the flights!
                  • Rod Musgjerd
                    • Sep 2020
                    • 9
                    • Helena MT
                    Nicely done Travis! I have to say it improves every time I see you fly it. Pretty cool to see each issue, solved as you move forward with the design.
