90mm power system in a 80mm airframe?
  • Mach351
    • May 2022
    • 26
    • TX
    I've been thinking about feasibility of putting a 3668-1960kv / 120 amp 90mm power system in either an Avanti or L-39 airframe... (or maybe a Cougar)
    Anyone done or attempted this? Thoughts?...
    Only found 1 other thread on this that didn't get any traffic: F14 soup-up from 80 to 90-105mm EDFs? - Hobby Squawk RC Forum for Airplanes, Boats, Cars, Helicopters, Tanks, and Trucks​
    There can't be only two of us that have thought about this.
    I'm not crazy, my mother had me tested. :)
    • 5426
    I did it to a F-86. I don’t suggest doing it.The swept area of a 90 means you need a larger outlet area. Just plopping a 90 in will probably result in less thrust than going to the newer 80mm 2150.
    when I did it I ended up with an old 6 blade 90 outrunner from the old F/A-18E and old Eurofighter. That worked very well. The fan was low power but more efficient than the old 80 in the F-86. It was also lighter weight. Ended up having more power but pulled lower amps so it had longer flight time too.
    • Mach351
      • May 2022
      • 26
      • TX
      makes sense. i was thinking restricted airflow into and thru the tunnel would probably diminish any real gain in thrust.
      i think it is time for a Zeus. looks like the air intake ports are large, and probably for a reason.
        • 5426
        The Zeus is a pretty awesome plane.
        • kallend
          • 1877
          Zeus, Vulcan, what's with the Greco-Roman gods?
          How about a Hermes, Athena, Aphrodite, Artemis, Ares?
