Question on the f15 90mm
  • Reptielenfreak
    • May 2024
    • 153
    So the f15 90mm is called heavy, a pig and all those stuff. But compared to the f22 90mm its only a 100grams heavyer if i read the specs, Is it such a difference? what is making it fly slow/heavy?
  • Reptielenfreak
    • May 2024
    • 153
    FYI
    Version Info: This is the High Performance version of the Freewing F-15C. As of 6/24/2024, this version includes a powerful 3668-19600Kv inrunner motor with 12-Blade EDF fan unit and a 120A ESC with thrust reversing.​
      • 5401
      Wing loading. F22 has a huge wing.
      • Reptielenfreak
        • May 2024
        • 153
        So does it need more runway aswell? My f22 on my field is sometimes on the edge when it comes to takeoffs if there is no wind.
        • stojakovic
          • Mar 2024
          • 19
          F15 without missles,with a little flap ,with 780G battery.it will takeoff less than 50m.
          • Reptielenfreak
            • May 2024
            • 153
            That would be perfect. I have about 70meters thanks for the info
            • shortround91
              • Nov 2023
              • 301
              • Princess Anne, Maryland
              I have the new version F15 HP use take off flaps have no issue taking off from a grass field with field to spare. She flies excellent sounds amazing with top notch landing gear, I own the 90mm J10 also and to me the F15 is much easier to land on our bumpy grass field. Only down side is DO NOT try to high alpha the F15 she doesn’t like that. Very very forgiving plane otherwise
              • Reptielenfreak
                • May 2024
                • 153
                Thank you for the info! I have a +-75m runway, its basicly a big cloth on top of grass. So it is very bumpy but smooth enough to get some speed.
                Thanks for the high-alfa tip. Will not try that one, haha.
                • shortround91
                  • Nov 2023
                  • 301
                  Definitely don’t won’t end well, I love the F15 other than the alpha such a forgiving jet take offs landings it does so well and relaxed
