EDF Jet --90mm LED afterburner ?
  • EDF Jet --90mm LED afterburner ?
    What are the best and simple to install LED afterburners for an Eflite 90MM vipor ?
    Thanks
    Gary
    The best are not the simplest to install, and the simplest are certainly not the best.
      I only use KMRC burners love the ease to program what I want about as simple as any other to install. You will need a Y cable as they are not provided with the burner
        Thank You for the reply. Does anyone have any suggestion for rates, expo's , mixing settings to start out as a intermediate ?
        Thank You
          My 35 year old AMA RC Club is all Electric. Many fly large heavy 90mm EDF Jets. A cell going bad in flight will crash the jet so we have this Battery Cell Sensor plugged into the LiPo Balance connector. But the Afterburner light also plugs in to it. We need a Y-connector for the two of them. Know where we can buy one?
              You can buy balance cable extensions and solder up a Y pretty easy. "large heavy 90mm EDF Jets", not flying 8S?
                I would love to post my own questions---lots of them---but am blocked and do not understand. Y cables on Amazon also.
                Thanks for the help.
                Grandpa Gary
                  Just get the one from motionrc website. Easy and affective i use them all the time
                    Get what? The afterburner? A Y? With what he is doing he still needs a Y. Of course, he could do what I do and run my AB through a 25V+ to 12V regulator. That way the AB is drawing off all 6 or 8 cells and not just 3 or 4 which will show an unbalanced pack through his cell checker.
                    • #11
                      If you mean the FW Tailflame AB, that may be easy but it is poorly designed, and lights up at idle speed so looks silly.
