I need help to figure out what the part is I need to order to replace the nose gear retracts. I dont need the wheel and down structure. Only need the servo. The black plastic is all cracked. Thanks,
Freewing a10 80 mm nose gear retract only
Oke, because your first message states:" i only need the servo". Also i was refering to the servo that makes steering the nosegear possible not the gear Doors.
Then you need this one..
I dont really understand the question.. the outside is plastic, the connection pins etc are aluminiumComment
Did you add the nose brace? I have a lot of flights on my a10 but when i installeren the brace and trailing LinkedIn gear i had no problems with cracked plastic casingComment
