Avanti substitute
  • jigeye
    • Dec 2018
    • 9
    Avanti substitute
    i have everything needed from a wrecked v1. cannot get spare part wings (out of stock). that being said, what airframe can i purchase using the avanti "stuff"
    • 8835
    What kind of "stuff"? Not likely body stuff will fit on a V2.
    Have you tried here:
    • jigeye
      • Dec 2018
      • 9
      Innards only. servoes/esc/fan/gear.. all the inside stuff. no body
        • 8835
        From your first post, it looked like you only needed wings because that's all you mentioned. Now it sounds like you need pretty much the whole plane except for those few things you listed.
        It'll be hard to find an "ARF". Most will be "ARF plus", which will have all the servos and retracts included. So, basically, all you've got that will be useful are the ESC, EDF. You can keep the servos and gear for spares for your next plane. Retract bodies are very similar from one plane to another (Freewing 80mm). Just remove the struts/tires. If you're only looking at Avanti S, then those bits will work in the V2. If you're not particular about an Avanti, then almost any Freewing 80mm ARF plus can use the ESC/EDF you salvaged from your old Avanti S.
