Hey guys, for anyone with a Freewing 64mm F-22 a great fix to keep the battery cool is to cut out the ledge in the back of the cockpit, set your radio down below the existing hole and cut the hole out a good amount to make it bigger. Then drill a couple of small holes in the front of the canopy and the air is sucked right out the tail keeping your battery barley warm..... I took out my pilot but you can keep yours in, I just wanted as much airflow as I could get running the power system I have in mine.
Most people put their radio on that ledge but that will block the original hole so don't put it there. This such a fun little jet and running my Don's Wicked 4S system it runs out around 70mph. With my paint job my AUW with the battery is 2.6 lbs.
