Yak 130 90mm
    Originally posted by pmdevlin
    Yes agreed. If I had a proven 6s set up, I can keep the esc, because and batts I already have, its just a new motor and fan, just need reliable take off, and a reasonable cruising speed that can manage loops etc
    The older 6s would have a really hard time to do a loop from a level pass. You'd have to dive the thing first to get it moving before entering the loop. Even then, it could fall out of the loop before getting to the top, so you must have some altitude or it'll take a dirt nap on the way down.
    If you go 8s, you can use the 6s batteries you have. Just buy a couple of 2s ones that match the brand and "C" rating. The 8s fan and HV ESC, however, will likely double the cost of your plane but in my opinion, if you really like it, it'll be worth it to be able to take off from grass in a fairly short distance and be able to do a loop from a level pass. If you are going that route, get the reversing ESC for those times you have a smooth runway. It's a heavy plane and will roll forever.
  • pmdevlin
    Ubec
  • pmdevlin
    I think you are finding why it was discontinued. At first it sold well but many found it very heavy flying. It didn't take long for sales to drop off. We now have more powerful fans but we didn't then. This plane still has a core group of people that like it but add that spares are sparse and I think people are selling the ones they have. The FW 90mm F-15 and T-45 are similar.
  • pmdevlin
    yes I then used a 6s, all was good, I did notice, I didn't check first, the ubec is rated as 6s, so I agree I was lucky. I'm struggling to come to terms with the cost now. Plane cost £200, I thought that was a good price as it all works, just the nose gear doors missing,. and I feel the nose retract is a bit weak. I wanted an 8s, It was sold as a 6s as the owner just didn't know,. he had it years in a shed,. never flew it. The expense there would be some batts. Now, as I pretty much know its 6s, to upgrade will be over £200, plus bats, making total cost way more than its worth. I would have been content with 6s as I don't fly fast, but it was so marginal on take off without ordnance, which I really want to use, Its now a big decision, I hate decisions!
    Did you throw a 6s battery back in to see if it arms and runs? If it works, you're lucky and didn't burn something up. The 6s version of this plane was meant for a long, smooth, flat runway so it can get up to speed to fly. Flying won't be comfortable or carefree as you'll need to keep the throttle near max. As it slows down in banked turns, the sphincter will get a work out.
    If you really like this plane and want to keep it, you should consider putting the 8s system I linked earlier.
  • pmdevlin
    Well I went brave! Made up a series connector for 2 x 4cell packs, and plugged it in, esc would not arm, so my esc is 6 cell.
    I'm really growing to like this plane just spent 2 hrs doing a manual set up on elevator to neutral out yesterday's flight trim, but the lack of power is an issue. I hardly fly anything past 2/3 ,throttle, this was flat out from take off, which it barely did, to landing, 3 mins 3.7 v per cell. It's too marginal to enjoy, I need to rethink this
  • RRHandy
    I managed a flight today! Took a while to figure out everything with the rats nest of wiring, but got there. After much bench testing, 1 of my 2 6s 5000mah 70 chl packs had dipped to 3.9v / cell so I dropped in the other fully charged one. I'm on a grass strip, it barely took off, almost stalled, once in the air very stable, I like it. With the batt all the way forward it climbed like crazy, took a lot of trim on elev. But, sadly it was very slow
    the unmarked motor and esc are def not stock, so I'm going to risk 8s, see what happens. My thinking is someone swopped out the stock esc and edf for a reason maybe ill get lucky!
    I have the 8s version and thou has power to take off, it by no means is fast, it's heavy without the battery's. It flew fine but not much faster than the 6s, One of the guys at another club has one and we flew together and at full I just pulled ahead.
    R.
    I would be cautious. The stock 6s Yak acted just like yours did - barely got off the grass and when it did, it stalled into a tree. If the tree wasn't there, it would have stayed airborne. An 8s Yak running on 6s would likely never leave the ground at all. Have a fire extinguisher on the ready.
    A true 8s running on 8s should get off short grass in about 150', even though once in the air, it's not all that fast, just more competent and quick to accelerate.
  • pmdevlin
    I can't be sure what year this was but here is the link of the PNP 8s that you could buy (before it went out of stock and has yet to come back):
    *** The Freewing Yak-130 red colour 90mm EDF Jet is the sport version and not include any missile set,  pilot figure and air brake function , photo just for reference only !  ***  - High performance electric ducted fan jet.- Incredible scale details includin
    I had the 6s before the 8s system came out and this is what I put in it:
     With Reverse Brake mode enabled when landing can effectively shorten the sliding distance of the aircraft to simulate the landing of a real aircraft ! - New Design Rotor Blade For High Thrust & Sound Performance.- Rotor Blade Material : Nylon Composite With Fiber-
  • pmdevlin
    appreciate your help Evan, good call, Ill put it back together (if I can decipher the rats nest of wiring!) and see if I can get some sort of thrust test, It would be nice to know what I'm dealing with, Its a great looking model, If all goes well, I will have to give it a repaint!.
    A rip off. When the plane came out what was in it was the best they had. Then they developed the 8S fan and people could put it in if they wanted more power. Just like if you buy a current plane there are more powerful fans you can buy to put in that plane.
    Can I suggest you see how much power it has on a 6s battery? If it makes about half the thrust the plane weighs it should tell you. But I can’t tell you about your ESC but would assume if it has a 8s fan the ESC would be 8s too.
  • pmdevlin
    here are a couple of pics, they might help if anybody can ID them
    so just to be sure, they made this model as a 6s set up. After that, there was a 8s upgrade, so not the complete model, just upgrade esc and motor? That's a bit of a rip off! they sell it underpowered,. but then give you the option of having what it should have had at the start?
    Was there a version where you fitted your own esc and fan/motor? I just cant see any freewing components not having any sort of markings on the parts, I'm nervous that I use 8s, which is what I want, and fry the esc and motor, if it happens in flight, that's the end of a rare airframe
    You have a 8s. There are some tiny set screws to pull the bullet cover off the back and you can see the motor markings. That is a really good fan.
    Just before it was discontinued ("out of stock" for years), a PNP 8s was available. However, even the 8s is very old, the 6s also very old and could be the same age if purchased near the end of that production run. Since you have the fan out, can you remove the motor and see if there are any markings on it? The 6s is about 1835kv, while the 8s is about 1390kv.
    As Evan said, I elected to upgrade mine to 8s after purchase for the extra power and reverse (it rolls forever on a smooth runway). The 6s barely got off a grass runway, which was all I had back then. Flew mine last week and 8s is the way to go with this big, heavy plane.
  • pmdevlin
    The fan has a red metal surround, with a red metal bracket to keep in place, and the motor shroud is the same colour, red, like an anodised finish. The esc has a plastic blue top to the case, and blue metal case . I'm surprised neither esc or motor have nothing in the way of manufacturer markings, or any space written on them. Seller thought it was 6s, but doesn't actually know, thanks
    The 8s was an after sale upgrade and had a red or blue shroud. What color is your shroud?
  • pmdevlin
    I'm stuck! Please help, hopefully someone is looking in
    ive aquired the 90mm yak, prev owner bought it second hand yrs ago, nobody knows if its 8s or 6s. Ive got the motor out, no markings, ive got the esc out, its enclosed in a blue anodised case, no markings. I think this is quite okd, it would be a shame to toast a 6s set up using 8s, or underpowered a 8 s set up using 6s! It has an airframe, can anyone say what I have!
    thanks
  • Jerry's Flying Circus
    I have the clear cockpit piece for this airplane. It is tinted. I will ship it to anyone who needs it in the US for $25. Let me know if you want them. Thanks.
