Does anyone have experience with attaching the rear section of the fuse, that followed the instructions? My question is...the instructions picture shows to put glue on the two spars but doesn't show to put it on the foam outline itself.
Is there anyone out there who followed that same instruction?
If so, has there been any issue with it separating during flight at all?
It seems that the instructions are that way so that its easier to replace that section if it gets damaged. However, it also seems that two much pressure in high fast dives or high rate pitch could put too much pressure in that section.
Thoughts from anyone with this new plane?
Thanks!
Thanks!
