Official Freewing 64mm F/A-18 Hornet Thread
Maiden flight today went well. flew straight off the deck, no trimming required, 4s CHNL G plus 70c 2200mah 3mins 18% left mixed power flight. 2 further flights , same pattern of climb figure of 8 , climb and roll, use rudders and counter aileron for flat turns, keeping speed up in turns, coast downwind, power up to full, climb, roll and loop off the top, power off, fly by, landings floats on in with minimum power, front suspension holding up well and taking out the bounce on our grass runway. for more power runs and more aerobatics need to set timer at 2 mins 30 to 2 mins 45 secs. Note, 3 mins not really enough time for a go around if you get it wrong !!!. Suggest practice landing approach with a minute left on timer to setup for landing on maiden flight -
Our field has now been cut and rolled, just waiting for suitable day and wind direction before maiden flightLeave a comment:
Thank you Paul! I’m going to get to work adding rudders before I maiden. Thanks for the detailed information and resources. I’ll share my experience once I get it together and up in the air.Jason TGY-1440A 4.5g 0.6kgf analogue servo from Hobbyking or any 5gm 0.6 Kgf 8mm thick MAX THICKNESS FOR A NEAT FIT servo you can find with correct connector end will work i had these in stock from a few years ago and they worked well on my F22 64MM. the nose gear you cannot buy, I made this up from a unit I had in the old spares box fitted into a cf tube with ply angle bracket to create solid support. Had a dozen flights on my F22 64mm no problems. The nose gear works well off my grass field ( short grass ) and the rudders work well for wingovers, landing approaches etc see this to check out requred servo calcs https://www.radiocontrolinfo.com/inf...ne-calculator/
-Jason
YAWspeed Jason. EMAX es9051 servos https://www.aliexpress.com/w/wholesa....home.search.0 also works also consider this
Jason TGY-1440A 4.5g 0.6kgf analogue servo from Hobbyking or any 5gm 0.6 Kgf 8mm thick MAX THICKNESS FOR A NEAT FIT servo you can find with correct connector end will work i had these in stock from a few years ago and they worked well on my F22 64MM. the nose gear you cannot buy, I made this up from a unit I had in the old spares box fitted into a cf tube with ply angle bracket to create solid support. Had a dozen flights on my F22 64mm no problems. The nose gear works well off my grass field ( short grass ) and the rudders work well for wingovers, landing approaches etc see this to check out requred servo calcs https://www.radiocontrolinfo.com/inf...ne-calculator/Leave a comment:
Nice setup! Do you mind sharing what servos you used and what parts you used for the nose wheel? I’m too nervous to fly mine without rudders, so I’ll be adding them before I maiden. Have you flown yours yet with that setup?
Thanks for sharing!
-Jason
With individual and functioning rudders, and upgraded E-flite 2840-3150kv motor and esc from their F15.2 PhotosLeave a comment:
My Freewing F/A-18E Super Hornet. I have added working rudders and sprung nose leg and twin nose wheels, 2200mah 4s 60c lipo. Takeoff weight = 1075gms with Xfly 64mm dia 4s 12 blade fan, 2840 3200kv motor, 50amp esc. 1250 gms static thrust 1000 gms actual. Now waiting for Spring when our grass field will be rolled and cut.
Would anyone happen to have a rudder set for this jet? Used in working condition is fine.
thanksLeave a comment:
We’ll it’s been a few years but the QX edf was the complete unit and 12blade out runner motor! You may want to look into the new freewing 64mm inrunner from Motion RC I believe it’s in the 64mm F22, go into the spare parts link for that airplane and it should be available.Leave a comment:
Do you have the exact QX edf unit number? Did you get the complete edf or just the motor? If the unit, was it 12 blade? I know this is an old post, but any info would be appreciatedJust my 2 cents.. I fly the F18 64mm using an admiral 4s 2500mah pro I’ve upgraded the edf to a Qx motor 3800Kv and use a ZTW esc 65amp, I use the landing gear, I feel it’s more realistic with the gear.. I think it flys great like this! In my opinion really no need to put a 70mm fan in it, and believe me I thought about it!. the air intakes are not designed for it and just adds weight that it doesn’t need!!Leave a comment:
I did not remove stock decals. I lightly scuffed the surface of the entire plane. Sprayed the whole jet with primer, then shot a flat clear over the primer. The primer is the correct grey to begin with so I left it as the base coat. I masked and painted all the gloss black on the spine and tails. The blue lines are also masked and painted on. The top gun decals are from Callie.
Hi Guys, I bought this flyer as a beginner, worked great for me but want to extend the flight time, anyone upgraded to a larger battery? Thanks!Leave a comment:
Here’s mine. Just got it a month ago. Haven’t flown it yet. Is the intakes and cheaters underneath it enough. I’ve seen other cut my holes for airflow. Is this necessary?3 PhotosLeave a comment:
Update on the F18 trim issue: I finally got the chance to fly it again today and there were very calm conditions. Nice flying. The bottom line is that my nozzle tweaking was exactly what I expected. The plane flew straight with no variations depending on throttle setting. I made 4 flights, 2 with my Roaring Top 35 C's, 2200 maH, 210 grams, and 2 with a pair of Zeee 50 C's 2200 maH, 241 grams. The CG was around 65mm just like before.
So my conclusion is that, not surprisingly, the nozzles are not just some decorative element on the plane. It's important that you glue them on very carefully, exactly flush with the matching surface, so that the exhaust goes straight out of the plane. The slight downward slant of my nozzles, which I didn't notice until I looked very closely, accounted for the plane diving when given throttle.
This should be explained in the manual or else the nozzles should be factory mounted. JMO
