Top RC Cougar Build
  • wolpertinger
    Originally posted by Saillfish
    I have this aircraft. Going with a KT85. I really don't understand where the CG is by the picture in the instructions. Can you help me out on where you started your measurement from?
    Saillfish,
    yes, CG not really clear. Looked at cougar build forums and found this to be the best explination. Spring is just around the corner and looking forward to getting my bird into the air..
    Good luck with the build...
  • Saillfish
  • wolpertinger
    Originally posted by Robert Belluomini
    That looks great! What size pack are you using?
    Going to with Gen Ace 6200 60c. Have some 5500 waiting in the wings.
  • Robert Belluomini
  • Flybeast
    It was my Pleasure !! it was a blast to work on and figure out new methods of building and layout for electronics .... Can't wait for Spring and Munice to see it Fly!
  • Prowler901
    She's a beauty! :Cool:
  • wolpertinger
    Ok, well all finished and waiting for Spring. Plan on a maiden at Muncie so hoping all goes well.
    thanks for the help Flybeast....
    Click image for larger version  Name:	20171222_122704.jpg Views:	1 Size:	334.0 KB ID:	109947Click image for larger version  Name:	20171222_122656.jpg Views:	1 Size:	348.5 KB ID:	109948Click image for larger version  Name:	20171222_122651.jpg Views:	1 Size:	353.7 KB ID:	109949Click image for larger version  Name:	20171222_122640.jpg Views:	1 Size:	358.6 KB ID:	109950
  • wolpertinger
    Just another update as we head into the final setup and testing.
    Completed final layout on the electronics and I added a Demon Cortex gyro to the plane. It is located right before the receiver so it is close to the CG
    Completed work on the Thrust Tube assembly. Got the Mylar from EFFlux RC. Still need to black out the tube and rear exit
Name:	EDF Thrust tube.jpg
    Test ran the fan unit and it makes some wind, just remember to test when rear of plane is not facing the table with Christmas cards. :Scared:
    Next is the installation of the Electrical wheel brakes. I ordered some JP Hobbies 80 mm wheels with brakes from EFFLUX but have an issue with the mounting.
    - JP has 6 mm shaft and Retracts have a 4 mm diameter for the axle.
    - The JP 6 mm shaft is to short for the Robart axle mount. It would only insert 5 mm if bored out.
    - Brake unit needs to be keyed when mounted or will rotate when brake applied. No grub screw to lock brake coil to the axle you need a square strut not round to key it.
    Nice wheels and brakes just not for this setup. Looks like I am better off with HK Mad Thrust units. Can save these for a different build.
    Next is the final push, wheels, pilot, CG, Verify connections and testing.
    Come on Spring.
  • Flybeast
    Hey guys ! As Wolpertinger has said im currently helping him get the cougar ready for the 2018 flying season !
  • wolpertinger
    Ok so here goes. Went over to build buddy (Flybeast) hangar and did some thrust tube calculations and componet layout for CG.
    FSA around 108mm @100% going to run around 99mm @ 85% for best over all performance.
    tube length is around 585mm. Thinking on mylar as building material.
    Looking at the electrical layout, this seems the best layout for access and CG can be adjusted using the reciever batteries mounted saddle bag over inlet ducts.
    I love the Cougar, and the JP EDFs are powerful. What outlet diameter are you going to use? What's the FSA on the stock inlets?
    I'll be in line for that Hunter. I love how those fly!
  • wolpertinger
    Well progress continues over at the hanger. Build buddy has been doing the EDF mounting. Looks like the JP Hobbie 120mm edf unit is a good for.
    Need make and install the thrust tube, finish electrical install, CG and test, test, test.
  • wolpertinger
    Hey Patrnflyr,
    Taking it slow and have a flying buddy working it too, but servos all in, body flaps working and Robart retracts in an operational. Now starting on making trays for electronncs and positioning batteries for CG. Still need to install the fan and thrust tube, wheel brakes and the list continues. This a first build like this so thinking it through as we go. Going to maiden in the spring at Muncie then take it EDF Jet Jam. Well thats the plan.
  • Patrnflyr
    Any more news on this? There's so few out there, info is really sparse. Noticed they are getting ready to release a new Hunter also in the RipMax size.
  • wolpertinger
    Tail section mounted. Another step forward. Click image for larger version
  • wolpertinger
    Thanks , tail section done and ready Click image for larger version
ID:	95732 for attaching.
  • crankestein
    Nice build, looking sharp.
  • wolpertinger
    Finished adding the servo for steering. Mix added for steering off when retracted....
  • wolpertinger
    Well the build continues. Did change up on servos. Went to Hitech HS5245Mg for elevator, flaps and HS645MG air and rudder. Using Dubro 2-56 ball links and rod with carbon fiber rod covering. For steering plan on using the 25mg servo from the Carbon Z T28. Fit right into the servo pocket on my Robart Retracts. The brakes were pnuematic but looking at JP Hobbies 75mm wheels with electric proportional braking.
  • Jake Noun
    Detectorall Co., Ltd. produces metal detectors and security devices with excellent quality and favorable price.View more details:
    gold prospecting
