54" F4D-1 Skyray
  • Corsair nut
    Just checked. 80mm is about 5.5 sq in for fsa. 90 is about 7.5 iirc. Ive flown edfs sucessfully down to 65% on the inlet side, with properly designed ducts. My lil 28" 70mm skyray had plenty of inlet and they were maybe a lil bit oversized. Id be more than willing to bet a 80 would work just fine wothout a cheater..and a 90 would even work awesome, especially if you have anywhere near 10 sq in.
  • Corsair nut
    Infact a 80 might be clpser to 6 than 7. Id need to look it up
  • Corsair nut
    .a 80mm only needs about 6 or 7 sq in. I think a 90 is around 8 or 9 sq in
  • Kloverzero
    Originally posted by Corsair nut View Post
    80mm would fly this thing awesome, and you womt need a lame cheater hole! :p
    The inlets are not going to be very big, probably 5 square inches each. It will need a cheater either way. It has plenty of duct space, but to keep the scale lines, I am going to have to go with the cheater.
  • Corsair nut
  • Kloverzero
    I missed that one Boots.........how about a refresher for us memory challenged Squawkers :P
    He is just making fun of me and my 18 pound King Kobra....
    Originally posted by Boots Whirlygig View Post
    You may have to Fiberglas this one! Reminds me of an funny story I read on the squawk....
    LOL
  • Kloverzero
    LOL
    You are not amusing...:Crying::Crying::Crying:LOLLOL
  • Boots Whirlygig
    LOL
  • Kloverzero
    This is really cool! Same materials as the Bronco, half inch blue with 3/16 sheathing and epoxy? Brilliant! I might build one as a belly lander, and power it with a 80mm 6 blade on 4s. Probably make a great edf trainer.
    Yup, same material as the Bronco!! After getting it off the bench last night, I am seriously thinking about shrinking the fan mount section and putting the 80mm fan in it. The top of the fuse doesn't even weigh 6 oz, I think the empty weight for this one is going to come in about 24 oz or so. That will put it all up minus the battery at about 4 lbs. There will be three servos (No rudder or flaps. Nose wheel steering and elevons), three retracts, receiver, ESC and fan. I am afraid that 90mm inrunner will tear it to pieces, because you know, if I have the power, I am going to use it!! I am taking a short stay home vacation, so today is my last day at work until Wednesday, so maybe, I can have it pretty close to finished by then, and get a maiden next weekend!!
    Here she is with the posterboard wing and tail templates!!
  • Boots Whirlygig
  • Kloverzero
    Progress from last night. I finally got her off the board!! Wow, super light and super strong!! She is straight as an arrow and very rigid. Tonight, I will get the upper ducting in and the fan mounts, get the top sheeting filled and sanded, and start working on drawing the bottom formers. I also went ahead last night and made the templates for the tail and the wing, so maybe I can get a few snapshots of what the whole picture will look like!!
  • Kloverzero
    Last nights progress...
  • Kloverzero
    Originally posted by dkalwishky View Post
    Remember the throttle is not boolean (off or on); you can fly at something less than full. Ha ha, just yanking your chain. I'm looking forward to seeing the completed plane and a flight video. This is very cool!
    I do not use the throttle stick for throttle, I assign the throttle channel to a two way switch;)
  • dkalwishky
    Originally posted by Kloverzero View Post
    I think I might should have stuck with the 80. I think the 90 is gonna put this thing into orbit. I already have all of ducting sized for the 90 though, so no turning back now!! To the moon Alice!!!
  • Kloverzero
    I have already determined that I am going to need a cheater due to the small inlets, but that is okay. Rather have the air and not need it, than need it and not have it!!! The way that I have the ducting worked out, I think I am going to add two louvers, one aft of each inlet, and I am thinking I may put one just forward of the fan as well. I don't want to compromise the duct too much though. I will have to do some wattage and thrust tests once everything has come together.
  • Corsair nut
    90 will be awesome. If it has the inlet area, why not :) my 28" wingspan depron version was 70mm amd it flew saweet. It is a skyray afterall..performance should be pretty spirited :) they set some records thats for sure. Such a cool subject.
  • Kloverzero
    I told ya a long time ago....freewing 80mm...cmon! :p ill settle for 90mm though....lolol
    That's pretty funny. My original intent was 80mm in this one, but once I got the drawings finished, and was looking at it, I thought an 80 might not have as much a$$ as I was hoping for. Now that construction has started, and I am seeing exactly what it will be, I think I might should have stuck with the 80. I think the 90 is gonna put this thing into orbit. I already have all of ducting sized for the 90 though, so no turning back now!! To the moon Alice!!!
  • Corsair nut
    Originally posted by Alpha.MotionRC View Post
    WANT!
    WANT!
