new HobbyZone Carbon Cub S+ motor pulsing
    • 8835
    It isn't the motor. It is the GPS, beginner system telling the pilot that the aircraft hasn't been initialized to home yet.
    Although he hasn't answered my question, I don't think he's looking to replace the motor in his Cub S (if he has one). He's looking at it for use in some other plane.
    • Sethjgreenberg
      • Mar 2021
      • 3
      To disarm GPS. Hold bind button and switch 3 position switch. Safe plus safe and experienced mode 3 times. It also helps lock GPS
      • HaileyFlyer
        • Jun 2021
        • Hailey Idaho
        I'm still struggling with setting my home field so th plane will stop pulsing, I may have set the field incorrectly. I also tried shutting off the gps not luck with that. Any suggestions?
        • HaileyFlyer
          • Jun 2021
          • Hailey Idaho
          Regarding a pulsing motor, I got help form Horizon Hobby Tech support. In my case I have a new NX8, even so I needed to download the latest software form SpektrumRC.com and update the NX8. Then I had to change the bind servo to down, the file I got from SpectrumRC for the Carbon Cub had the bind button in the up position, which is incorrect. Hope this is some help. If not call tech support,
          • glideher
            GLider Hero
            • Oct 2017
            • 14
            i have read somewhere this issue can be due to a loose battery plug off the ESC's end, anyone check this to be true?
            DLG GLiders
