Dynam Waco (Red)
  • PappaBear
    • May 2015
    • 377
    • California
    Dynam Waco (Red)
    A few weeks ago I had the opportunity to assemble and fly the 50" red Waco from Dynam. As most of you will know Dynam is an economy or budget range of models and for the price, I believe they are an excellent range of models. They all fly very well. I will be the first to say their quality is perhaps not to the same standard as Flightline RC or Freewing, but then neither is the price. Anyway, back to the Waco.
    I've always liked bi-planes and the Waco has a certain appeal and is quite an aerobatic machine. The proportions look right and I believe if it looks right it will fly! The model is a typical Dynam model. The servos are all installed as is the motor and the ESC. The model assembles quickly and can be ready to fly in a couple of hours. Before I started to assemble I tested all the servos and centered them. I connected the aileron servos to the ailerons before I fitted the wings to the fuselage. This is a personal preference and I believe it is easier to make adjustments to the pushrod to obtain the correct length.
    The landing gear is simply attached to the bottom of the fuselage with the screws provided and foam infill glued over the top of the cross piece to continue the round shape of the fuselage. The cabines (center struts) are screwed to the fuselage with screws and reinforcing mounts are fitted to the inside of the fuselage for this purpose.
    The vertical and horizontal stabilizes both had slight warps in them, which I corrected with the warm water treatment. The vertical stabilizer is glued to the horizontal and the assembly is attached to the rear of the fuselage with screws. The elevator and rudder pushrods are then attached to the control horns and the control throws adjusted.
    Incorporated in the wings are lights together with the wires which lead into the fuselage and then connected to a spare channel of the RX. The bottom wing is simply attached to the bottom of the fuselage with the bolts provided. It's now time to fit the interplane struts and the top wing. It's at this point you will discover if you have the cabine struts the correct way round. If everything is looking good the top wing will simply line up with the cabine struts and the interplane struts and then secured with the screws. Please NOTE DO NOT use loctite to secure the small nuts and screws together. They fit through plastic parts and loctite will crack and break the plastic. As loctite drys out it expands in the threads to secure the nut and as it does so it also expands in the plastic and this is what makes it break. No form of thread lock is required. This is an electric model and it will have very little or no vibration to cause the nuts to come loose.
    All that is left to do now is to add the RX and balance the model. My model balanced perfectly with the battery slightly forward and I have the RX behind the battery. At this point, I carried out a throttle/motor calibration and lastly, the prop can be fitted and secured with the domed nut.
    I'm flying the model on the recommended 4s 2200mAh battery and this will provide a flying time of between 4 and 5 minutes depending on the type of flying you are doing. The model will take off and land very easily and it's what I call a no drama model, there are no unpleasant surprises. It will loop, roll, 4 point roll, fly inverted and perform snap rolls with ease.
    It's a delightful little model with great aerobatic capability.
    Martin.
    Hello Martin,
    I was part of the handful of Squawkers back in the day that encouraged MRC to bring the yellow Waco into the at that time small line up of Dynam birds carried.
    With that being said, still have it and have well over 300 flights on it. I do put it through some heavy G stresses which does cause loosing of the hardware on all the wing struts.
    Since as you pointed out that Loctite is NOT plastic friendly, would highly recommend that pilots use some Foam-Tac on the nuts of these connections.
    I would also open up the 6 o'clock position of the faux radial to allow more air to enter into the air channel that is directly behind it so as to provide much better cooling to the ESC.
    If someone is interest in having a larger gas tank for longer flight times, this bird will take a 4000mAh 4S Admiral(that's what I use) with no mods and about 2mm up elevator trim.
    Your evaluation of it's flight characteristics I totally concur with.;)
      One of the best Dynam planes, I love mine and fly it often.
      • doctormike
        HobbySquawk Moderator
        • Oct 2013
        • 1260
        • Santa Fe NM
        I just received mine.( I already have the yellow one). Haven't pulled the stabs out of the plastic yet, but they actually look like they may not be warped! Dynam might just be pulling it together. Doc
        • Hippie 64
          • Feb 2014
          • 1049
          • Gaffney , S.C.
          I have the Yellow and absolutely Love it !! It is one of the best planes I have ever had . I added the rigging to it and put Snoopy behind the stick . Also put Dave Brown wheels , they fit great under the wheel skirts
          Bryan
          But Crashing is Landing
            Originally posted by Hippie 64
            I have the Yellow and absolutely Love it !! It is one of the best planes I have ever had . I added the rigging to it and put Snoopy behind the stick . Also put Dave Brown wheels , they fit great under the wheel skirts Bryan
            I remember when you got that Hippie ;)
            • Hippie 64
              • Feb 2014
              • 1049
              • Gaffney , S.C.
              Charlie I am Truly happy with the Dynam version. It is built sturdy and has a great wing span . For me flying off grass it does very well !!!! It's been awhile , had to look back to see and my video shows the maiden early 2015 ... WOW
              Bryan
              • dkalwishky
                Warbird Lover
                • Sep 2015
                • 1382
                • Des Moines, IA
                I picked up the Yellow one at an auction earlier this year. I really like the way it flies and it looks great in the air. Dynam certainly got it right with this one.
                • boomer108
                  Chief Boom
                  • Apr 2014
                  • 868
                  • Chicago IL.
                  I have the yellow one also and it is a great flyer. I also used some foam tac on the cabane screws for extra insurance and put 3 inch Dave Brown's on her. I'm using a 4s 3000 battery with 13/4 ounces of lead in the nose and also opened up the cowl for more air like Warbird suggested. She flys cool as can be.
                  • quitcherbitchen
                    • 927
                    • Altadena, CA
                    Looks like Barbie had some bad cosmetic surgery George. I hope you weren't the surgeon? LOL
                      That's an old hotrod dash bobble, it's so old her hair is starting to come out.
                      • NoDirt!
                        • 183
                        I also have the yellow one. I replaced the cabane screws with slightly loner ones with a very carefully placed tiny touch of Loctite. Opened up the "engine" too. It still flies great after several years on 4s 2200's
                        • doctormike
                          • Oct 2013
                          • 1260
                          • Santa Fe NM
                          I wish I could find an appropriately sized Homer Simpson somewhere! Preferably with an extremely frightened look on his face. Any help? Doc
                          • fhhuber
                            • Aug 2015
                            • 1476
                            Search for the Pez Homer head
                            https://www.amazon.com/Simpsons-Set-.../dp/B007M4KZY8
                            Unfortunately its a desirable Pez set (and you pretty much can only find the set)
                            Or peruse the toy aisle at Wal-Mart.
                            I took a Sylvester (cat) head and changed it from looking like he's just talking to looking scared to death by using a couple of sharpies (mainly altering the eyes)
                            • doctormike
                              • Oct 2013
                              • 1260
                              • Santa Fe NM
                              Thanks. I guess I'll have to put my sculpting skills to use with some Sculpy and make a mold. I want his hands clutching the side of the cockpit. Doc
