TiredironGRB's Flightline 2000mm B-24 Review and Build
    I received the B-24 today, it shipped from China and the box really showed it...even though the box was very beat up there wasn't as much as a scuff on the model, very well packaged. I can't say enough about the quality of this model, the fit, finish and detail are outstanding and as you will see in the pictures it's a modeler's dream canvas.
    Click image for larger version  Name:	20171127_181857583_iOS.jpg Views:	1 Size:	145.3 KB ID:	105911
    Click image for larger version  Name:	20171127_185352630_iOS.jpg Views:	1 Size:	160.0 KB ID:	105915
    The same wheels as the Freewing 1700mm A-10, nice detail on the struts.
    Click image for larger version  Name:	20171127_231448752_iOS.jpg Views:	1 Size:	93.6 KB ID:	105913
    Very glad to see the sturdy prop adapters on the B-24 instead of the weak 4mm threaded motor shafts used on other large bombers.
    Click image for larger version  Name:	20171127_231530036_iOS.jpg Views:	1 Size:	109.0 KB ID:	105914
    Tons of room in the waist gunners area.
    Click image for larger version  Name:	20171127_231644763_iOS.jpg Views:	1 Size:	49.9 KB ID:	105912
    The slot to remove the servo arm screw is a nice touch.
    Click image for larger version  Name:	20171127_231436104_iOS.jpg Views:	1 Size:	56.1 KB ID:	105910
    Click image for larger version  Name:	20171127_233030699_iOS.jpg Views:	1 Size:	114.1 KB ID:	105920
    Click image for larger version  Name:	20171127_235326459_iOS.jpg Views:	1 Size:	93.7 KB ID:	105919
    Click image for larger version  Name:	20171127_235341392_iOS.jpg Views:	1 Size:	84.8 KB ID:	105918
    Here you can see the hinges for the nose gear door upgrade are already in place.
    Click image for larger version  Name:	20171127_231724556_iOS.jpg Views:	1 Size:	71.2 KB ID:	105916
    The nose gear should hold up good since the strut is so short.
    Click image for larger version  Name:	20171127_231708678_iOS.jpg Views:	1 Size:	73.0 KB ID:	105917
    This is inside the nose, lots of room for detailing.
    I love these props, very scale appearing with all the hub detail. The hub is painted metal gray and the bell is silver...I can see where these props will be an upgrade for all my B-17s.
    The battery compartment is huge and there's plenty of room behind it for electronics.
      I started work on the turrets and FPV camera installs, I used a cut down tail wheel servo tiller to move the nose turret.
      Made a foam servo mount for the top turret.
        reserved 3
        • TSHobbies
          Hobby Squawk Warbird Pilot
          • Nov 2015
          • 671
          • Cartersville GA
          SAWEEEET! I just a thought...since you mentioned the wheels being same as the FW A-10..wonder if the gear & wheel would fit the A-10 ? for us asphalt landers...
          www.TSHobbies.com
          • ryramZ
            Pilot Ryan
            • Dec 2012
            • 814
            Great detailed pics! Oh my goodness I think I need A green one! Ahhhh
              Everyone should have one of each ;)
                Looks great so far George! Following along with great interest.
                • Regatoni5
                  • Nov 2017
                  • 137
                  • Lemoore, San Diego
                  bet you wont...
                  • borntoolate
                    Bomber Bob
                    • Mar 2013
                    • 424
                    • California
                    Nice George! Looking on!!!!
                    Bob
                    • themudduck
                      -TMD- Foaming at the Mouth!
                      • 1041
                      • Burton OH (near Cleveland)
                      Thanks for the pics, it looks really good. Its very exciting! What size is the prop (DxP)?
                        Wing loading:100g/dm²
                        Wing area:35dm²
                        Motor: 3530-860KV brushless outrunner motor (4pcs)
                        Propeller : 3 Blade 9.5x7
                        ESC : 30A(4pcs)
                        Servo : 9g digital metal gear servo (9pcs)
                        Flight speed:110KPH/70MPH
                        Empty Weight : 2910g(without battery)
                        Pull: 5400g
                        • ryramZ
                          Pilot Ryan
                          • Dec 2012
                          • 814
                          Originally posted by Regatoni5
                          bet you wont...
                            Lookin' good George. Can't wait to see what you do with it.
                            • Prowler901
                              • 940
                              • Gunnison, CO
                              Thanks for all the pictures and details, George. It's gonna be hard waiting for January.
                              • Regatoni5
                                • Nov 2017
                                • 137
                                I was joking, egging you to do it
                                • dkalwishky
                                  Warbird Lover
                                  • Sep 2015
                                  • 1382
                                  • Des Moines, IA
                                  I've never ordered two of the same exact plane, while I have many Corsairs they are different sizes and manufactures. I've got the green one preordered, I may just go ahead and preorder the silver one as well.
                                  I love the B-24!
                                  George, what camera are you using for the FPV?
                                  • quitcherbitchen
                                    • 923
                                    • Altadena, CA
                                    Any shots of the canopy?
                                      I love the B-24!
                                      These are the 200mw Boldclash camera for viewing but I record with a small Quelima SQ11
                                        I love the B-24!
                                        These are the 200mw Boldclash camera for viewing but I record with a small Quelima SQ11...for the record I ordered a silver one as well ;)
