F2G balancing?
  • Tim
    • Jan 2015
    • 12
    F2G balancing?
    I use Great Planes balancing machine. The book for my F2G Corsair says to balance it with retracts down, and I was reading other forums and they say to balance it wheels up? (Makes sense since the plan is not flying with the retracts down) I love this plane and I'm afraid of messing it up on maiden flight. Any advice?
    • 7349
    RE: F2G balancing?
    Hi Tim, I'd suggest that you look on you tube under Motion RC or check out the video on the motionrc webpage for the Corsair.  I don't know which brand or scale you plane is, but I've found that creating your own you tube channel and checking out motionrc and rcinformer are a lot of help.  That said, most planes with retracts are balanced with the wheels up, this being the position for flight, however, with a bent wing bird, it might be different and as I don't own one as of yet, I'd hate to say one way or another.  Worse comes to worse, go to the support page and drop MotionRC an e mail, they're great people to deal with!
    Good luck to you, how about it guys, all the corsair owners out there?
    • Hippie 64
      • Feb 2014
      • 1049
      • Gaffney , S.C.
      RE: F2G balancing?
      Hey Tim , as a rule when you have gear that retracts always put them up . When you fly your gear will be up . On a Corsair the gear goes back when retracted throwing your CG back . also be sure you turn your plane upside down . Any low wing turn over , any high wing keep upright when your doing the CG .
      Bryan
      But Crashing is Landing
      • Tim
        • Jan 2015
        • 12
        RE: F2G balancing?
        Bryan
        Thank you Hippie. I'm going to rebalance wheels up, and it should let me move my battery forward more which I thought was getting to far back to achieve proper CG. Nice jet by the way. I'm going to put my Corsair on here shortly.
        [hr]
        Thank you Grossman. Much appreciated. :)
        • Hippie 64
          • Feb 2014
          • 1049
          • Gaffney , S.C.
          RE: F2G balancing?
          We look forward to it Tim
          Bryan
          • fieldofdreamsflyer
            Banned
            • Jan 2013
            • 289
            RE: F2G balancing?
            You  balance it upside down with gear up. The gear rotates back behind cg. you fly mostly with gear up
