Power Loss
  • Falcon 291
    • Dec 2017
    Power Loss
    Just purchased a Sukhoi. After setting it up everything was fine. I wanted to set the motor to have a shut off switch and after that things went wrong. I'm new to trying to program a radio. Mine is a Spektrum dx8 gen 2. If I apply full power immediately the motor goes to full power then slows down and stops. If I apply low power the motor turns on real slow then just stops I have fully charged batteries with proper C rating. Anyone got any idea what Happened?
    Welcome to Hobby Squawk!
    Have you tried calibrating the ESCs?
    • Falcon 291
      • Dec 2017
      I'll see if I can figure that out thanks
      • Gilatrout
        RC Pilot Addict
        • 806
        • Albuquerque NM
        Most likely the esc, but an older battery or one that was stored charged will develop high internal resistance. The battery may appear to be 100% charged, but due to the resistance the power isn't delivered
        • fhhuber
          • Aug 2015
          • 1476
          Goes to full power, then without moving the stick it slows and stops = charge the battery. or your battery can't handle the current demand and tripped the low voltage cutoff.
            • 7333
            or a dead cell
