Just purchased a Sukhoi. After setting it up everything was fine. I wanted to set the motor to have a shut off switch and after that things went wrong. I'm new to trying to program a radio. Mine is a Spektrum dx8 gen 2. If I apply full power immediately the motor goes to full power then slows down and stops. If I apply low power the motor turns on real slow then just stops I have fully charged batteries with proper C rating. Anyone got any idea what Happened?
Power Loss
Tags: None
Most likely the esc, but an older battery or one that was stored charged will develop high internal resistance. The battery may appear to be 100% charged, but due to the resistance the power isn't deliveredJust purchased a Sukhoi. After setting it up everything was fine. I wanted to set the motor to have a shut off switch and after that things went wrong. I'm new to trying to program a radio. Mine is a Spektrum dx8 gen 2. If I apply full power immediately the motor goes to full power then slows down and stops. If I apply low power the motor turns on real slow then just stops I have fully charged batteries with proper C rating. Anyone got any idea what Happened?Comment
Goes to full power, then without moving the stick it slows and stops = charge the battery. or your battery can't handle the current demand and tripped the low voltage cutoff.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
