UMX Waco
  • IowaTim
    • Jul 2018
    • 18
    UMX Waco
    Does anyone know if this battery will fit and connect properly to the UMX Waco? I've heard that this is a better battery than the E-flite version .
    Here's the E-flite version for reference. https://www.motionrc.com/products/e-...nt=19075543750
  • fhhuber
    • Aug 2015
    • 1476
    Probably won't fit without cutting foam.
    The space for the battery in the ultra micros is designed around the battery.
    It wouldn't be a significant upgrade.
    You'd need a wattmeter to see the difference in power due to lower internal resistance (probably after the decimal point) and flight time would at best be 7% more.
    This assumes the C ratings are meaningfully relatable to internal resistance....
    • CaptAmerica
      Ghostrider
      • Jun 2018
      • 187
      • Ohio
      I've used the kinexsis 280 and 300 mah batteries in both the UMX waco and pitts. Connect and fit with no problems.
      • IowaTim
        • Jul 2018
        • 18
        I can also now confirm that the Kinexsis 300 fits with no problem, after purchasing both the UMX Waco and Kinexsis battery. Thanks for everyone's help!
        • Gilatrout
          RC Pilot Addict
          • 806
          • Albuquerque NM
          I use a pulse brand 300mAh battery in most of my umx planes. Fits fine and nice long flight times
