Yeah that would be hell to find for sure
HELP! FMS B-25 Mitchell PnP 1470mm Green FMM025PGRN
Sure was...it was a hot day and the Soy Bean plants are thick and tough as well as chest high.
I tried using the game trails and farmer trails out there but a few times I had to carefully wade thru the morass.
It is like wading thru quick sand.
At one point my legs started cramping and I thought I was getting heat stroke or something.
Also, I think every reptile and insect species lives in that field...got mosquito bites on my back and arms.
The foam was on its last leg anyway, but man....the RX, battery, and servo's that were lost really stinks.Comment
I never got to fly it as there was a "Flying Wing" racing event going on at my club field.
So after eating 2 Hot Dogs, watching the racing and picking the brains of the old timers, I went home to work on my other FMS jet so I can take them both tomorrow to my clubs flying field, as there is no events tomorrow to keep me from flying.
Please see my thread regarding my FMS T-35 GOSHAWK, I cannot seem to get the new EC5 plugs soldered.Comment
Try this ...
The thing is I am soldering an EC5 connector on the ESC end, not the battery end.
That is why I have no room to work with, as the wires are very short from the ESC and I have to do the soldering inside the foam cavity.Comment
Take the ESC out of the plane if you have to ... easy enoughComment
If you take the access hatch off pull the fan and esc assembly out, you can get it done super quick and easy. When room is a premium, its the best thing to do.Comment
Well, I tried to maiden the FMS B-25 Mitchell again, but I think I need to upgrade the nose gear.
When the plane first begins to move, it veers to the right, and then when I try to get it straight it goes to far to the left.
Basically, every single time no matter what I try, it does a very hard"S" turn, first right then left.
When I examine the nose gear I notice two things.
First, it is already starting to bend or shift backwards slightly.
Second, although there is a little bit of play, the nose gear does turn left and right.
It does this on pavement and short cropped grass.
Not sure what to do at this point.Comment
Put 40% expo on your rudder, it will tame down the ground handling.Well, I tried to maiden the FMS B-25 Mitchell again, but I think I need to upgrade the nose gear.
