This new thread is to serve more or less of my activities inside and outside of the Tengarang hangar pertaining to the electric foam fixed wing niche.
Tengarang's Avenue concerning Lord Emperor Teng's Weekly Field and Hangar Maintenance Activity
Dear Friends and Colleagues, hope Thanksgiving was as good as it was for me as it was for you guys. Its the start of the holiday season, the weather now is perfect, the cooler winter air is starting its way towards us, and the nights are becoming ever so silent. The moon speaks to me every night when i look up upon her, shes always got something profound to share and reflect upon me, and glad shes always there to offer her light.
Weather Permitting:
As for the maiden flight of The Tengarang Airlines Flight 911 AKA Aircraft#52 set and scheduled for tomorrow November the 24th of 2018. I have set aside two flights for Aircraft#52, the first flight will be done with the new Dual venom 5000mah 30C 4s packs, one for the inboard nacelles and the other for the outboard nacelles. I will attempt to give her enough roll out before rotation to ensure a smooth take off, and will dial plenty of exponential on the rudder while she is on the ground to buffer the nose gear setting. As soon as she gets off the ground, ill make my best attempt to get her trimmed out and land her asap to monitor the battery charge level to fine tune the flight timer, and help better prepare the second flight.
In addition to the the deployment of Aircraft#52, i have decided to deploy two flights of Aircraft#1 Stewie's GeeBee as the presiding flagship of the tengarang fleet will oversee and monitor the crew of Aircraft#52's progress. Stewies ships specification is shown in the excel chart attached to this message, and will be equipped with a single 2200mah 4s pack. Also will be Stewies first time deployment at Livermore Flying Electrons.2 Photos
- Likes 5
https://www.youtube.com/watch?v=T0Aa...QtwWkFAOrcgxx7
Maiden Flight November 24th 2018
Livermore FLying Electrons
Aircraft#52: Tengarang Airlines Flight 911
Q-motor 3500KV 2822 size outrunners
12 blade 64mm Q-motor Fan
Dual 4s 5000mah 30C Discharge rated Venom Packs
Wing Cub Loading Index: 25.69684306
Wing Loading: 13.38950869
Projected flight time with empirical Data minimum 4 minutes
https://www.facebook.com/LordEmperor...type=3&theater
Second Flight of Aircraft#52 can also be viewed on youtube.
Dual 4s 3300mah 45C Discharge rated China Hobbyline Packs
https://www.youtube.com/watch?v=1K4z...QtwWkFAOrcgxx7
Last but not least the Dynam GeeBee Aircraft#1 in the tengarang fleet was also dispatched as Presiding Chairman overseeing the crew of Aircraft#52 Tengarang Airlines Flight 911
10 Photos
- Likes 7
Documentation Mission #2
Mission Date Saturday: December 8th 2018, a day which will live in Victory...
I am engaging Bomber Escort flight assignments for Borntoolate's Bomber Command deployment. High command has informed De Porchetta's bomber command about enemy positions near the Livermore Flying Electrons Fort William Henry Corridor; and that the corridor must be held for the Ground Assault of Patton's infantry forces. While participants of Borntoolate's Bomber formation(s) has not been fully decided yet, i have assigned the following Chaperons to protect Borntoolate's Bombers while they deliver their payload:
Aircraft # 8 Tail Dragger Military/Fighter FMS Hellcat 1100mm Aircraft# 11 Tail Dragger Military/Fighter Eflite P-47 1200mm
While these two fighters are among-st the elite fighter groups of the Tengarang fleet; this will be first time #8 and #11 will be deployed at the Livermore Flying Electrons Arena...
If interested the specifications are shown in the chart below for the corresponding aircraft assigned to this mission.7 Photos
- Likes 4
Video from Mission#2 Aircraft #8 take 2ℝℂ ???????????????????????????????? ℝ???????????????????? ℂ???????????????????????? ???????????????????????????????? ℝℂ ℙ???????????????? ℝ???????????????????? ???????????????????????????? ???????????????????????????????? FMS F6F Hellcat 1100mm
- Likes 3
Video from Mission#2 Aircraft #11 take 2ℝℂ ???????????????????????????????? ℝ???????????????????? ℂ???????????????????????? ???????????????????????????????? ℝℂ ℙ???????????????? ℝ???????????????????? ???????????????????????????? ???????????????????????????????? ???????????????????????? - ????47???? - ????47 Eflite P-47 Razorback 1200mm
- Likes 4
Mission #3
Aircraft#32
Eflite Maule 1500mm (EFL5350)
Motor: BL15 1050KV
Propeller: 11x7x2
3s 4000mah
Radio: DX9
Receiver: Spektrum AR636 ReceiverAircraft#32 Eflite Maule 1500mm (EFL5350) Motor: BL15 1050KV Propeller: 11x7x2 3s 4000mah Radio: DX9 Receiver: Spektrum AR636 Receiver Lord-Emperor Teng of t...
- Likes 4
Mission #3 External View
Aircraft#32
Motor: BL15 1050KV
Propeller: 11x7x2
3s 4000mah
Radio: DX9
- Likes 3
Mission #4
For the next mission I will be deploying three Chinese Peoples Liberation Army Air-force fighters at Livermore Flying Electrons.
AirCraft No. Class Application Aircraft Name
35 64mm Tricycle Gear Military/Fighter TWM J-10B
47 80mm Tricycle Gear Military/Fighter Freewing Mig-21
48 70mm Tricycle Gear Military/Fighter TWM J-11B
- Likes 6
Mission#5 debriefing
Had a great time and enjoyed the beautiful California weather sailing the “USS Pier Pressure Titanic II” on standby coast guard rescue duties.
Aircraft #32 Eflite Maule from the tengarang fleet has completed its float fly mission Saturday 19th of January.
The flight was un eventful however a bit on the challenging side when coming in for final approach as the pond itself is limited in size. Had to engage half flaps and dead stick her for the most part while keeping the nose pitched up as the kinetic energy of the aircraft bleeds of to a safe approach touch down speed, as water landings are much more difficult to execute compared to asphalt and grass landing.Tengarang Fleet Aircraft#32 Eflite Maule 1500mm BL15 1050KV Prop 11x7x2 Battery 3s 4000mah Radio DX9 Location: Classified Mission: Operation Amphibious Happy...
- Likes 2
Todays activity:
There has been some Re-Organization with in the Tengarang Fleet. I traded in three Vessels: aircraft 15, and 40, and aircraft#2 from the border control detachment for the For a BNF version of the Eflite 1200mm P-51D.
15 Tail Dragger Military/Fighter Durafly MK24 Spitfire 1100mm UK
40 67mm Tricycle Gear Fictional / Civilian TWM Nemo USA
2 Helicopter Civilian Chinook Walkera#38 USA
Up to date the tengarang fleet consists o 49 Operational aircraft with two additional aircraft under construction
aircraft#51 Eflite P-51D and aircraft#46 (former aircraft#48) USS War Cry
Aircraft#46 "USS War Cry" progress report update. The main length of the aircraft has been defined. the Under carriage footprint and layout positioning has been determined. Next step is to determine how the nose wheel steering servo should be placed to allow efficient and reliable re tractability.
More construction efforts will resume later this week as the gorilla glue sets.
- Likes 2
A vessel is a ship or a large boat ;)and I didn't see any seaplanes in that list LOLWarbird Charlie
:Cool::) Yeah i get this alot....Originally posted by OV10 View PostA vessel is a ship or a large boat ;)and I didn't see any seaplanes in that list LOL
i suppose i have John Wayne Flying TIgers film to blame. The Skipper often refers to his P-40's as "Ships" growing up its been ingrained.
But i know what you mean ...
- Likes 2
Lord-Emperor Teng
11 hrs ·
Progress Report Aircraft#46 "USS War Cry"
She received her coat of white gloss paint this morning and the first set of cosmetics. The center of gravity is six inches from the leading edge of the wing. Esc Electronics have been calibrated with low voltage cuttoff set at 11.1V for emergency power reduction protocol, which will be well below the 4s nominal lvc for theae super simple esc’s from hobbyking.
Next Steps
Schedule for Maiden Flight at Livermore Flying Electrons
Possible mods for the pipeline down the road is to implement 3-axis gyro.
Aircraft#46 Tengarang Fleet Designation: USS War Cry Propulsion power plant: TWM Outrunner 28/31 3030KV Propulsion Unit: TWM Stock PL6800010 Power Source: 4s...
- Likes 6
.png)
