FMS 800mm T 28
  • #21
    RE: FMS 800mm T 28
    Dead Bird Slow motion flip over landing on this one! Lol!
    From this afternoon!
    • #22
      RE: FMS 800mm T 28
      I think you did pretty good considering all of your gauges were frozen :angel:
      Steve
      AMA 95495
      Freewing P-51D Iron Ass
      Freewing F-86 80MM
      • #23
        RE: FMS 800mm T 28
        Greetings T,
        I believe that stiil technically counts as a landing!!!
        Bill L.
        In Okla.
        • #24
          RE: FMS 800mm T 28
          Thanks Steve, Bill. Yeah, I need to check the instruments again on their operation. Maybe they are all frozen... Good excuse for all of the flip overs! Lol!
          • #25
            RE: FMS 800mm T 28
            Horrid crash from yestarday, with the FMS T28 800mm. I lost orientation down low as the tree line was in my background.. Ouch!
            • #26
              RE: FMS 800mm T 28
              Thosmosis was there anything left?
              Off with one helluva roar!
              AMA 1085465
              • #27
                RE: FMS 800mm T 28
                All three prop blades disentigrated, the motor completely ejected from the nose -- hanging by wires. Front gear a tad bent. Both rear gear knocked off...
                Amazingly, no wing damage. And I had completely reglued one side of the wing after another crash that shorn it off... Way to go, Gorilla Glue...
                Nose could be slightly compressed... Will need to check... After a previously compacted nose, it looks surprisingly undamaged. But need to make sure it's straight...
                Of course, the motor mount is what got destroyed... And the cowl... Could be all repairable for minimal $$. I am almost tempted to just get another one. Super robust foam, if it can put up with my flying skills, with this little amount of damage at high speed...
                I totally blew it... No fault of the plane.
                • #28
                  RE: FMS 800mm T 28
                  But the two way radio sounded like it was still working! ;)
                  Lauren
                  • #29
                    RE: FMS 800mm T 28
                    Hi Lauren. Yes -- it was a Radio Shack, two way from the 70's... Bulletproof!! Lol
                    [hr]
                    Drat! The T28 800 "motorboard" Pa111 is out of stock everywhere, including MRC. Available direct from FMS for only $3.00... Hey, wait, what's the problem with that?? You say?? Shipping for the part is almost $30! Lol! Double Drat!
                    • #30
                      RE: FMS 800mm T 28
                      Yes she has been airborne several times after my mishap, until yesterday. Was flying indoors with it, Applied throttle rolled out nice and smooth lifted off, starting to bank left so i applied right rudder rudder and elevator to correct , started going to the right slowly, so i applied the throttle to climb out slowly and then it happened.
                      As i applied more throttle, I seen it shake a little and it went hard right straight down into the astro turf. Broke the motor plate pushed the motor up into the cowl. bent the prop shaft almost 90 degrees and took off the front wheel. Funny thing is my prop didnt break, course im using a prop adapter and amaster air screw prop. So off I go to fix her. She will fly again soon
                      • #31
                        RE: FMS 800mm T 28
                        Sorry to hear about your crash Fozzy... We are both in the same situation. Broken botorboard. I can't find one anywhere... And a cowl for the grey Navy version...
                        • #32
                          RE: FMS 800mm T 28
                          Yes sir, Im going to fabricate my own motor board my buddy used to own a custom car shop, so his abilities and imagination are endless. As for my plane, I have its little, and big brother to fly.
                          Micro T 28 and a 1100mm, hopefully around the holidays I will buy the 1400mm and then the Carbon Z Trojan. Love these planes want a whole squadron of them.
                          • #33
                            RE: FMS 800mm T 28
                            What caused that?
                            Lauren
                            • #34
                              RE: FMS 800mm T 28
                              I just found the Grey T28 800mm FMS... Just ordered another one... With the extra parts of two planes, I should be set!!!
                              https://vortexhobbies.com/fms-800mm-t28-grey-pnp-fms032p-gry-p-152719.html
                              FMS 800mm T28 V2-Grey PNP
                              Model: FMS FMS032P-GRY
                              Dist. #: FMS032P-GRY SKU: FMS032P-GRY
                              Be the first to review this product. (Write Review)
                              In stock
                              Price: $99.99 & FREE SHIPPING
