FMS 1400mm P-40B Pre-order is up
  • FMS 1400mm P-40B Pre-order is up
    The pre order can be found here: http://www.motionrc.com/fms-p-40b-warhawk-flying-tiger-1400mm-55-wingspan-pnp/
    A few details about this plane:
    • The retracts are all new and specifically developed for this plane
    • New upgraded 4258-KV650 motor and 70A ESC
    • Shock absorbing metal oleo landing gear struts
    • Retractable tail wheel with metal trunnion
    • No more foam hinges! Nylon hinge material on control surfaces
    • Screw in servo pockets. No more glued in servos! A bad servo can be replaced with 2 screws
    • Digital metal gear servos throughout
    • Ball links on all control surfaces
    • Split flaps with an amazing amount of detail
    • Easy single wire quick connectors to remove the wings
    • Slide out battery tray for easy battery changes
    • Super high fidelity scale detail throughout
    RE: FMS 1400mm P-40B Pre-order is up
    Sounds good Tom, the only thing that concerns me is the plastic casings for the retracts, are they the same as what we have on the other 1400mm warbirds and if so, will the CNC
    Smallparts replacements for pivoting retracts fit on them?  I know they just finished developing them, any idea?
      This is a brand new retract made at a new factory. I've only see the prototype. Not sure if the final version will be any different yet so unfortunately I'm not 100% sure.
        Hey Tom, is Ryan getting his hands on one of these for a video?  I've watched Rich's and they're pretty good, but let the boys have a wack at it too!
        One thing that I'm trying to see is whether or not the cockpit has any detail?
        All I can see from the glimpses in the video is a shoulder high Pilot and a pretty non existent cockpit.
          Rich makes a lot of his videos with pre-production versions of these planes. We always wait until we have a full production version so you see exactly what you would get. FMS tends to make changes until the last minute so we've learned to wait on any FMS video until we actually receive the containers with a new plane inside. At that point we'll build one and shoot some video.
            Wow, while there is nothing lacking in the 980mm P40B, I have to say watching Rich Baker flying the 1400mm P40B down on the deck, and with the turn and burn stuff just makes the wallet twitch.
            While she appears to be slower than the 980mm in both speed and roll rate she appears to be a bit better than the 980mm on landing. I love the split flaps. That is one of the few knocks against the 980 P40B in that the flaps are not split!
            I love watching the high G turns with the tips holding on tight. No signs of an impending tip stall. Just love the way Rich shows off these models. After watching him fly these products, I know I can't say that my flying will be "equipment limited"!
            Something gotta give and soon, I fear it will be my wallet.
            All the best,
            Konrad
              As a matter of interest, I've noticed that the 'other' company is including all the extras that Motion is, but they're also including a battery.
              Is that included with your deal?
                The battery is random. FMS has included it in 10% of the boxes. We felt is was not enough to advertise it. The package is 100% the same.
                  Thanks Tom!
                    Check out the build guide in "All Us Intermediates, Lets Share"
