Dynam Bf-110 motor issues
  • TSHobbies
    Hobby Squawk Warbird Pilot
    • Nov 2015
    • 671
    • Cartersville GA
    hey guys..finally got the 110 together ,wired up and ready to ground test it..but having motor issues. I followed the steps in the video on MRs site about resetting it to factory, but that didnt work..In fact,mines not really acting like that.. what both motors are doing is stuttering , acting like they want to go in both directions..meaning, they stutter one way,then go back the other direction ,and repeat..if I advance the throttle further, they either stop working,or just delay,and go back to stuttering. any ideas whats might be going on here?
    [hr]
    Heres what its doing,sorry for the poor quality
    https://youtu.be/JIBdr5Vp3CY
    www.TSHobbies.com
  • ryramZ
    Pilot Ryan
    • Dec 2012
    • 814
    RE: Dynam Bf-110 motor issues
    [hr]
    Have you also calibrated the ESCs? It kind of sounds like a bad connection.
    • TSHobbies
      • Nov 2015
      • 671
      • Cartersville GA
      yes I have. and its connected securely.
      [hr]
      www.TSHobbies.com
        Hello TSH,
        Dynam 30 and 40amp ESC's will demonstrate that pulsing characteristic more often than not if the 'timing' is not set for LOW. The higher rated amperage ones seem to be fine.
        Best regards,
        • TSHobbies
          • Nov 2015
          • 671
          • Cartersville GA
          I followed the video to reset the ESCs,but I think that method sets them to medium...how do you set it to low?
          www.TSHobbies.com
            Hello TSH,
            All the Dynam's that I have came with an inclusive document in the assembly manual called " Manual of Brushless Motor Speed Controller" or a separate pamphlet titled the same. If you are not comfortable programming the ESC's via your transmitter and listening/interpreting sounds then get this programming card.
            http://www.motionrc.com/dynam-esc-programming-card/
            Best regards,
            • TSHobbies
              • Nov 2015
              • 671
              • Cartersville GA
              mine didnt come with that manual
              www.TSHobbies.com
              • fhhuber
                • Aug 2015
                • 1476
                Just get the ESC programming card... especially if you have a few of the Dynam ESCs it is well worth having.
                Turnigy's programming card that looks the same is the same. (I have both) Cross-matches to several of the Chinese ESCs.
                To safely test an ESC programming card on a different brand ESC: Note the light settings when you first use the card. If the results of changing the "I'm alive" music setting is not appropriate then put it back the way it was.
                You could actually develop a set of notes for the different effects of using the card with any ESC that can be programmed by a card. They just change the order of the buttons.
                • fieldofdreamsflyer
                  Banned
                  • Jan 2013
                  • 289
                  Med should work fine , dont put it to low cause you will lose top power
                  • TSHobbies
                    • Nov 2015
                    • 671
                    • Cartersville GA
                    lol, well, thanks, but that plane was sold off along time ago.
                    www.TSHobbies.com
