Product page: https://www.motionrc.com/products/bl...lga-2240mm-arf
PZL-104 Wilga is a Polish short-takeoff-and-landing civil aviation utility aircraft designed and originally manufactured by PZL Warszawa-Okęcie, and later by European Aeronautic Defence and Space Company, who had acquired the original manufacturer during 2001.
The model is scaled to approximately 1:6.5 and attention was paid to a true to original appearance and best flight characteristics. The model was designed for electric drives but can also be operated with an internal combustion engine about 15cc displacement.
Features:
Features:
- High level of prefabrication right out of the box
- Lightweight, strong, and fully sheeted laser cut balsa and plywood construction
- Covered in high quality Oracover
- Heavy-duty hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed dummy radial engine, cockpit and interior included
- Fiberglass control horns with ball link connector
- Pull-Pull control system on the rudder for precision control and authority
- comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly.
- Fiberglass cowl
- Mounts for both electric and gas power options included
- Fully illustrated instruction manual included and also available for download (see tab above)
- Black Horse PZL-104 Wilga 2240mm (88.19") Wingspan - ARF
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 1500-2000 Watt brushless outrunner motor - we recommend the Admiral GP20 6320-295kV Brushless motor
- 60-100 Amp brushless ESC - we recommend ZTW Gecko 120A ESC OPTO High Voltage
- 8x 45g standard servos - we recommend Hitec HS-625MG
- 8-18 Amp UBEC - we recommend ZTW 18A BEC/UBEC
- Electronic 90 degree retracts (81 x 44 x 29mm) - we recommend Xwave RP400-90 Electronic Retract (coming soon)
- TWO 4 Cell 14.8V 5000mAh 60C LiPo Batteries with EC5 connector - we recommend TWO Admiral Pro 5000mAh 4S 14.8V 60C LiPo Batteries with EC5 Connector
- EC5 2 to 1 Series adapter - we recommend Admiral EC5 2 to 1 Series Adapter
- Electric propeller - we recommend APC 16x10 Electric Propeller
- Engine: 25-30cc 2-stroke - NGH GT25 recommended or 30-40cc 4-stroke - NGH GT38 recommended
- Gas Propeller: 15x8-16x10 (2 Stroke) 18x10-20x8 (4 Stroke)
