I'd buy one if it were available.
Request for a P-61 in 1600mm or larger?
Is this wishful thinking or do you have an inside track cause I'll definitely go with door #2(Monty or Wayne innuendo):cool:Originally posted by TSHobbies View Postare preorders up for this yet? :rolleyes:Warbird Charlie
The Black Widow's iconic name sake was because of the special formulated gloss black that was derived as anti-spotlight camouflage but it also wore OD green, admiral blue and sandy brown. The Navy vet in me will opt for the blue. Here's another very interesting fact, it used the same R-2800 class of radial engine that was used on the F8F. So FL has now released the Bearcat which means they already have the powerplants for the Widow. OK FliteLine, MAKE IT SO but actually use the P-38's motors cause they're a 20kV higher rating.Originally posted by Grossman56 View PostIt would be cool I'll give you that.
The only argument I can see, other than the usual, would be that it would be in black and black foam will not like the heat too much.
Just saying
Grossman56Warbird Charlie
Would purchase a p-61 without hesitation(only have room for 2 more aircraft once the mig shows up )and based on the number of views a p-61 would be as big a hit as the p-38. Any chance the rc community can figure out a way to make black finish work? Primer/top coat? Base coat /protective finish? Space shuttle paint? OD or sand would still be a beautiful model but black finish is the iconic version. Even if black not offered i would love to see decals and antenna included for blackwidow version. Now if santa can get this done by Christmas, i see a very large box under the tree. (my wife cant argue about a gift from santa,right?)Still flying P.15, avanti(#2), mig 21, yak 130 70mm(#2), f35, f9f panther, a10 64mm, F8 crusader/ PA ultimate amr /HK skipper, durafly dh vampire, p 51,spit mk24, corsair, flybeam/ BH f86 50mm, deltawing 50mm/ HH su 26 mm,umx pitts,umx sbach, blade nano cp s,blade 450x, inductrix 200, inductrix pro, umx yak 54,umx f27 fpv/ electrifly 4s L39/ flyzone beaver/ volantix asw 28, /dynam B26
