B-25
Dear Aros, if you can tease Alpha to go in the direction of a big Flightline B25.... well all I can say is that if that happens I will sell my LX for scratch.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
Hi guys, I'm battling to get the Retracts and sequence doors working on my B25 Mitchell from Dynam. I have connected all the servo leads as per the manual instructions. I even followed the manual in connection with the sequence doors and gear module that is fitted to the plane but everything else works besides the landing gear and sequencer doors? 😭Comment
Could you be pugging them in wrong, is the controller working, is the radio setup right? Red to + and black to -, sometimes those control boards don't show the pattern. or your radio is set for a different switch.Hi guys, I'm battling to get the Retracts and sequence doors working on my B25 Mitchell from Dynam. I have connected all the servo leads as per the manual instructions. I even followed the manual in connection with the sequence doors and gear module that is fitted to the plane but everything else works besides the landing gear and sequencer doors? 😭
Hope that helps.
R.AMA 424553Comment
You mean the LX? Dynam doesn’t make a B-25...Hi guys, I'm battling to get the Retracts and sequence doors working on my B25 Mitchell from Dynam. I have connected all the servo leads as per the manual instructions. I even followed the manual in connection with the sequence doors and gear module that is fitted to the plane but everything else works besides the landing gear and sequencer doors? 😭Comment
Anyone still flying this model on the stock power system ?
I bought this used and was wondering if I could at least use two blade props to address the power issues .Comment
Besides the countless post on power issues, an old video popped up from Angry Zeppelin testing & delivering 8 lbs of torque at full power . The model has to be heavier than 8 lbs. I would imagine it’s not pulling more than 100: watts a pound with a fully charged pack at full throttle ?Comment
Which model exactly are you referring to? The newer Flightline B-25, or the older LX/BH B-25?Besides the countless post on power issues, an old video popped up from Angry Zeppelin testing & delivering 8 lbs of torque at full power . The model has to be heavier than 8 lbs. I would imagine it’s not pulling more than 100: watts a pound with a fully charged pack at full throttle ?Comment
There are no power issues.
Torque is a force over a distance like 100 ft/lb.
Maybe you are thinking 8lb thrust?
Link to video?
the LX B25 , is this the Motion thread , if so excuse the error.
Trying to solve a power issues on an old bird picked up at a value.Comment
Thanks and good to know , I hate to lose this bird, I did a lor of mods and repainted. Only paid $200 for it but it was worth the effort . I was going to change out the ESCs and motor but its not an easy task , requires more then a simple swap out. The weathering is obviously not accurate lol , I didn’t care , i was just going for fun effect .6 PhotosComment
