Looks like more Nexa birds on the way...
Nexa Expanding
In fact, we'll be bringing in the smaller SBD (1540mm) eventually as well, after some slight tweaking. In the meantime, the big SBD makes a nice base for customization and added detailing.Originally posted by SanExup View PostI agree! I hope they make the A24 as an SBD in that size as well.
Hoping you guys are bringing in the Val at some point too! Just in case you are, I want to share my experience with that model:
- First, the pilot figure is... awful. I ejected him and put in one that looked like an IJN flyer. Also, including a second crewman for the gunner/radio operator would be nice.
- Please include a scale IJN 250kg bomb. Dive bombers without ordnance just look wrong!
- Don't know if it was just missing from my VQ model, but please include a dummy radial.
- The landing gear wire is really soft. Even good landings on grass runways will bend them. A sturdier solution is required.
- The plastic wheel pants fairing (which is glued to the wing) is fragile and prone to breaking when the pants inevitably contact them on landing. In part, due to the soft wire landing gears...
- Finally, the soft wire means that the aft end of the wheel pants frequently impact the underside of the wing. The pants hold up well, but the wing suffers.
The plane itself flies well. I've moved my CG ahead of the suggested point as I found it a bit sensitive at first. I'm using a Power 52 on 5S, with a 13x8 3-blade prop.
.png)
. I was giving the P-38 a look over as well. Some pics show gear doors some do not. Are they included?
