Official ZOHD 570mm SonicModell Dart 250G - PNP Thread
  • jbaartz
    • Sep 2020
    • 488
    SonicModell Dart 250G 570mm (22.4") - PNP from ZOHD - ZOH10056
    Based on the great reputation of the Dart Wing family and the invaluable info gathered from top world-wide FPV pilots, SonicModell was able to develop new techniques, and after tons of tests and refinements, they are finally bringing you the finest sub-250 ship in the market: The ZOHD Dart250G.
    Using their default configuration and the recommended FPV gear, it is 100% under 250 grams. To the untrained eye, she will look like a harmless toy but this is a super capable FPV ship that will even let you do long-range like the bigger sisters. Being so light, it’s a blessing for beginners since they will find that it is really hard to break it.
    Easy Assembly and Transport
    The detachable wing and vertical fins makes the Dart 250G easy to transport.
    Durable, Impact-Resistant
    The Dart 250G is molded in durable EPP, built-in CF spar for enhancement, stable flying capability and impact resistance.
    Large Battery Bay
    The Dart 250G incorporates a large battery bay for your chosen FPV equipment and electronics.
    Glue-Free Assembly
    Glue-free assembly, the main wing and tails come with pre-applied 3M adhesive.
    FEATURES:
    • AUW is less than 250g, ideal to comply with Sub 250g regulations
    • Durable EPP material, built-in CF spar for enhancement, crash-resistant
    • Being light-weight will be safe to fly anywhere, anytime. You're avoiding the hassle of an FPV registration
    • Glue-free assembly, the main wing and tails come with pre-applied 3M adhesive
    • Large battery bay for extended flight time
    • Nose camera bay compatible with all FPV and AIO cameras in the market
    • Teflon cover for the fuselage bottom, super durable, protecting the fuselage bottom from scratches
    • Servo arms are well protected by an EPP hump
    • Built-in CF rod in the ailerons will give precision and sharp action to your inputs
    • Dedicated equipment bay for Flight Controller and GPS
    • Main wing leading edge cover for those unexpected impacts
    • Textured areas on both side of the fuselage, for more secure hand launch grip
    • The optimized air-cooling design will keep your gear safe from overheating
    INCLUDES:
    • ZOHD SonicModell Dart 250G 570mm (22.4") - PNP
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Wingspan 570mm / 22.4in
    Length 379mm / 14.9in
    Weight (w/o battery) N/A
    CG (Center of Gravity) Refer to manual
    Power System 1406-2600kV Brushless Outrunner Motor
    Electronic Speed Control 30A
    Propeller / EDF 6x3
    Servos 9g metal gear
    Landing Gear N/A
    Required Battery 3 Cell 11.1V 800-1500 mAh LiPo Battery (required)
    Required Radio 4 Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material EPP Foam
    Skill Level Intermediate
    Build Time 1 Hour
    Recommended Environment Outdoor
  • BigEye
    • May 2021
    Does anyone know what the empty weight (no battery or camera) is for the Dart. The description assures us it is under 250g and the Specifications indicate an empty weight of N/A. For those who are interested in keeping under 250g this would be nice to know to understand what limitations you would have for battery and camera options to stay within the limits.
      You will need an all in one camera unit, and biggest packs are as recommended 1500mah. This is not going to be any kind of explorer under 250g, more so it will be 200-400 yard flyer. If you go with larger more powerful vtx power and flight controllers and stuff, it will edge into the registration requirements. I recommend this fpv unit.
      Amazon.com: Wolfwhoop WT03 Micro FPV AIO 600TVL Camera 5.8G 25/50/200mW Adjustable Transmitter with Cloverleaf Antenna for Mini Aircraft: Toys & Games
        Amazon.com : AKK Micro FPV AIO Camera (600TVL) and 5.8G 0/25/50/200mW Switchable Transmitter With Clover Antenna for FPV RC Car Fpv Drone Quadcopter Micro RC Plane Whoop Blade Inductrix (with shell) : Camera & Photo
        • quietfly
          • May 2018
          Is it a 3s lipo with either prop? The model came with a 3blade and a two blade prop.
