Official Skynetic Bison XT STOL Discussion Thread
AussieHoppy looking at your photos, that most certainly should be called a ShockingCub, anyone with any small amount of know how on how lift from wing shape works could see that the setup pictured was doomed to be a disaster, and to be honest I am not sure why it would have even been produced as a prototype let alone go into full production. Seagul used to make good planes, they were the first non diy plane I ever owned, don't they test fly anything before going into production anymore? To be honest I am SPEECHLESS after looking at the shocking Cub -
I don't know at the moment. As per usual all the containers bypass us and head around the other side of the planet first. I'll keep an eye out around the usual Asian retailers, I might see if Budget Hobbies or even Metro Hobbies will stock them, but most likely Aussie retailers will be ordering through an Aussie wholesaler like OMP so we'd have to wait months (literally) for the last container out of the manufacturer. And as you mentioned, trying to purchase from USA is pretty much financially unjustifiable these days due to crazy freight costs.
I'd really like one of these but I'm going to have to be patient...Leave a comment:
... also you start by talking about the slats but then call them the flaps. I agree that the gap between the front of the FLAPS and the rear of the wing should be as small as possible, but the gap between the front SLAT and the leading edge of the wing is designed so that the flow over the slat joins up and sits on top of the airflow that goes under the slate and over the wing leading edge, see from the 3 minute mark of this youtube https://www.youtube.com/watch?v=TgncesRfqho ,also have a look next time your in a Qantas or Virgin jet taking off or landing, there is NO gap between the flaps and the trailing edge of wing and a reasonable gap between front SLATS and leading edge of wing. it is designed to give an almost second wing worth of lift due to two layers of air having to travel faster than the air under the wingOooops! My apologies! I knew what I was talking about... 😏 swap "flaps" in this line for "slats", it might make more sense lol
I wasn't intending to make any reference of the flaps other than the slats actuated by the flap servo.
What you've stated there, is what I was failing to say :)
From what I have read (yes, text book learning only, soon to experiment real world) the gap between the leading edge of the slat and leading edge of the wing is generally a reasonable sized gap, where-as the gap between the trailing edge of the slat and wing surface is a much smaller gap, for reasons you have already noted (airflow/boundary layer).
But the slat setup on this Bison has the slats hinged and actuated by a pushrod off the flap servo, it looks to me like the pushrod pushes the slat up which closes the leading edge gap a little but worse, it lifts the trailing edge of the slat up creating a very large gap. With the trailing edge of the slat up high it doesn't encourage smooth airflow over the wing but act more so as an airbrake and creating a bunch of turbulence which disturbs the boundary layer, counterproductively.
The Seagull Savage Shock Cub had the same setup and didn't work, in fact a few guys quickly crashed it because with the slats standing up it was destroying lift at stol speeds and creating turbulence not unlike an air brake. Most guys either fixed them in place or removed them completely.
Seems to me the slats should be on slides if they are to be actuated by the flap servo, so being pushed forward the leading edge slat gap opens up while the slat trailing edge remains the required smaller gap.
I should look into the Freewing T-45 Goshawk with their leading edge slats done properly. Quote from MotionRC's site:
"The Freewing T-45 sets itself apart from the competition with numerous scale details and innovative features such as servo actuated speed brakes and plastic wormgear-driven slats. These slats are the first production release of a proper slat in a foam model of any size, and use aluminum tracks to ensure proper extension geometry. Other plastic details include a row of turbulators on the wings..."
I love these slats! Have a peek at the comparison pics attached.
I like the idea of turbulators or VG's too, but that's another discussion lol
And for stol I don't mind at all a gap between trailing edge of wing ~ flap leading edge, like you achieve with offset hinges, this creates turbulence and acts as an airbrake where it should.
Sorry guys for the essay [my fingers are typist cramping now...], the only reason I am encouraging this topical discussion is because guys crashed their 1/4 scale Cubs underestimating the air brake/lift destroying slats that lifted at the rear... hoping to highlight this issue here so guys don't crash this Bison inadvertently, is all.
How about naming or nominating an Australian distributor that us aussies can buy it without the almost $600AUD freight fee, Pleeeeeeeeease
hey alpha! What about the floats? I know there was talk about it before? What is the update on the floats?
Motion RC Team, Kindly please help:
1. Please advice to where all the screws are used (size wise) . Nothing in the assembly guide indicate to what screw size goes to the undercarriage, struts, tail wheels, stabilizer or the main wing.
2. I connected the light controller to the gear channel. After a couple minutes, the controller got very hot to the point that controller shrink tube starts to melt.
Kindly please advice. Thank you in advance.Leave a comment:
Looks like I’ll have to make my own interior details. Still going to be a fun plane.Leave a comment:
Some pictures of the Bison for everyone to enjoy. We found the bison to be a super fun bird to play around with, its all terrain suspension is super durable and took tons of incredibly hard test landings with ZERO issues. With The Bison over 100 test flights on it, we found that you can obtain a better flight envelope than the majority of other brand stol birds, especially if you add a gyro like some other brands. the leading edge slats are an awesome option but we found that the bison really only needs minimal deflection in them to get the best STOL landings and takeoffs. As Ive seen mentioned in previous posts the tires should be glued onto the rim with “Rc car tire CA” but applied in small amounts and only in about 1/2” lengths until both sides are completely glued in place. You can put too much pressure into them so at first, only get the tire pressurized to hold the weight of the bison without being too soft and sloppy on the ground. As a recommendation, add some CA to the wingtip lights because after lots of flying, the double side tape will eventually un-stick and you dont want to loose the light assy. For best results give a quick burst of throttle right before landing to cushion your landings.
All in all the Bison is large durable stol bird that loves the off road approach to the rc flying hobby. have fun with the Bison because we have.Leave a comment:
Hey AussieHoppy where will you be buying yours if you do go ahead, see my comment above re freight also you start by talking about the slats but then call them the flaps. I agree that the gap between the front of the FLAPS and the rear of the wing should be as small as possible, but the gap between the front SLAT and the leading edge of the wing is designed so that the flow over the slat joins up and sits on top of the airflow that goes under the slate and over the wing leading edge, see from the 3 minute mark of this youtube https://www.youtube.com/watch?v=TgncesRfqho ,also have a look next time your in a Qantas or Virgin jet taking off or landing, there is NO gap between the flaps and the trailing edge of wing and a reasonable gap between front SLATS and leading edge of wing. it is designed to give an almost second wing worth of lift due to two layers of air having to travel faster than the air under the wingLeave a comment:
I would love to order one of these, I already have the motionrc 4s F-22 70mm F-35 80mm A-10 and the AL37 on its way by slow boat from China, but motionrc are quoting me $550 AUD for the plane and another $578 AUD for delivery and being on an Australian disability pension I just can't afford it, so looks like I just keep saving the rest of the money needed to buy the parts required to build my DIY C-130 seeing as no manufacturer wants to release one with a 3.5mt wingspanLeave a comment:
Ordered mine this afternoon when I did my hourly check to see if it was available lol. Anyone know if this has a modeled dashboard?Leave a comment:
Thanks. Just unbox and manual is missing. Looking good so far.Also, here is a digital copy of the manual for the Bison Save the trees! (that you'll be bushwhacking in your new Bisons)
Bison XT STOL - Assembly Guide - 7.1.2021Leave a comment:
Nice vid! I loved the one wheel touch-n-go 😁Product video: https://youtu.be/y6O3URxQzGk
I am new to STOL, I am curious about the leading edge slats. The flap servo appears to push the slats up at the rear edge? The 1/4 scale Seagull Savage Shock Cub has the near exact same slat actuation and from what I have seen and read, this does nothing for the boundary layer but kills lift and acts as an air brake.... am I incorrect? The little bit of research I have done says the gap at the trailing edge of the slats should be narrow allowing air to flow over the top wing surface, lifting the trailing edge of the flaps seems to do nothing but disturb the air flow creating disturbance over the boundary layer, which is counter-productive for STOL?
Don't get me wrong, I'm waiting for solid layman's video reviews to come forth, the price point and accessories and size makes this STOL Bison a very attractive temptation, but the slats may not be as functional as they should be, perhaps they should be actuated forward rather than up?
I dunno, until we see some real STOL landings, can someone please educate me? ☺Leave a comment:
Tom, Alpha. I ordered mine today, what a long strange trip to get here
Looking forward to the floats in timeLeave a comment:
Tom is right, among all the craziness associated with international overseas container shipments in the current era, we had never heard nor encountered a random 3 week delay in Chicago.
Thankfully, they're here, and they're shipping.Leave a comment:
Sorry for the delay, the container was in Chicago for the last 4 weeks stuck in US Customs. They flagged the container for a random inspection and then told us their warehouse was overfilled and they did not have time to inspect it. Never heard of that before. That caused a 3 week delay while we waited with no information and no ETA. Frustrating! At least it is here now and we're super excited about it! Thanks to everyone who ordered already.Leave a comment:
