Yak 54 3D 1100mm (43.3") Wingspan - ARF BUNDLE from Skynetic - SKY1012-002
Click here to access the official product page
The Skynetic Yak 54 EPP is a 3D flyer made of durable EPP foam that can perform show-stopping 3D maneuvers with ease. The Yak 54 EPP has been structurally-enhanced with carbon fiber support rods and strips throughout for weight-saving yet extreme rigidity for those High G 3D maneuvers up your sleeve. With a streamlined and aerodynamic profile, the Yak 54 EPP is tailor-made for countless hours of outdoor exhilarating, flying fun!
FEATURES:
- Slick, streamlined and aerodynamic profile with sharp sunburst livery
- Carbon fiber support rods and strips throughout to promote extreme rigidity
- Wind-resistant, durable and rigid airframe allows for both indoor and outdoor flying
- Powerful AS2216 KV1250 brushless outrunner motor for a wide flight performance envelope
- Skynetic Yak 54 3D 1100mm (43.3") Wingspan - ARF BUNDLE
- AS2216 KV1250 brushless outrunner motor
- 30-amp brushless ESC with XT60 connector
- 4x 17g micro servos
- 4 Channel Radio - Select a minimum 4 channel radio from our Radio Collection
- 4 Channel Receiver - Select a minimum 4 channel receiver from our Receiver Collection
- 3 Cell 11.1V 1300 - 1800 mAh Li-Po battery with XT60 connector - We recommend EPR16003X6
- 2 X 12" Servo extension leads - ADMSERVX300
- 1 X 4" Servo "Y" lead - ADMSERVYX150
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 5 HOURS
| Wingspan | 43.3in / 1100mm |
| Length | 47.2in / 1200mm |
| Flying Weight | 650 - 750g |
| CG (Center of Gravity) | 96 - 114mm from the leading edge of the wing at the root |
| Power System | Powerful AS2216 KV1250 Brushless outrunner motor (installed) |
| Electronic Speed Control | 30-amp brushless ESC with XT60 connector (installed) |
| Propeller / EDF | Electric propeller |
| Servos | 4x 17g micro servos |
| Landing Gear | Fixed |
| Required Battery | 3 Cell 11.1V 1300 - 1800 mAh Li-Po battery with XT60 connector (required) |
| Required Radio | 4+ channel radio system (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Foam |
| Material | EPP Foam |
| Skill Level | Intermediate |
| Build Time | 5 Hours |
| Recommended Environment | Indoor/Outdoor |
.png)
