Trainer King 1118mm (44") Wingspan - ARF BUNDLE from Skynetic - SKY1022-002
Click here for the official product page
The Skynetic Trainer King EPP is a high wing trainer that is perfect for learning how to fly. Both wing and gear are easily removable for transport and/or flying preference. Made of light yet durable EPP foam with a high and ample-cambered wing and rugged tri-gear, the Trainer King is tailor-made for anyone wanting a capable trainer for flight training.
FEATURES:
- Durable EPP and high wing with large camber to increase trainer capabilities
- Rugged and strong tri-gear for added insurance on takeoffs and landings
- Easy to remove wing and horizontal stabilizer makes transport a breeze
- Skynetic Trainer King 1118mm (44") Wingspan - ARF BUNDLE
- AS2216 Brushless motor
- 30-amp brushless ESC with XT60 connector
- 4x 8g servos
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 3 Cell 11.1V 1300 mAh Li-Po battery with XT60 connector - we recommend the Admiral 1300mAh 3S 11.1V 25C LiPo Battery with XT60 Connector
- 3 Cell compatible battery charger - select a minimum 3 cell (3S) charger from our Charger Collection
AGE LEVEL : 10 AND UP
SKILL LEVEL : BEGINNER
BUILD TIME : 2+ HOUR
Wingspan | 44in / 1118mm |
Length | 37.4in / 9580mm |
Flying Weight | 600 - 650g |
CG (Center of Gravity) | 57 - 63mm from the leading edge of the wing at the root |
Power System | AS2216 Brushless motor (installed) |
Electronic Speed Control | 30-amp brushless ESC with XT60 connector (installed) |
Propeller / EDF | Electric propeller |
Servos | 4x 8g |
Landing Gear | Tri-gear Fixed |
Required Battery | 3 Cell 11.1V 1300 mAh Li-Po battery with XT60 connector (required) |
Required Radio | 4+ channel radio system (required) |
Ailerons | Yes |
Elevator | Yes |
Rudder | Yes |
Flaps | No |
Lights | No |
Hinge Type | Foam |
Material | EPP Foam |
Skill Level | Beginner |
Build Time | 2+ Hours |
Recommended Environment | Outdoor |
