Dancing Wings - Sopwith Pup
  • Dancing Wings - Sopwith Pup
    Building Log of the Sopwith Pup from Dancing Wings
    K0601
    Wingspan 378mm
    Length 280mm
    Flying Weight 42-50g
    Suggested BL Motor 1104 3700KV
    Suggested ESC 5A /1S
    Suggested Servo 1.7g * 2pcs
    Suggested RX ≥3 CH.
    Suggested Prop 4.5-5inch
    Suggested BATT 1S 200-250mAh
    It is "only" for building practice with a balsa kt. My last one ("Der kleine Uhu" from Graupner) I have built around 40 years ago.
    And I like old Bi Planes a lot
    Click image for larger version  Name:	IMG_1246.jpg Views:	0 Size:	150.2 KB ID:	320772
    Click image for larger version  Name:	IMG_1247.jpg Views:	0 Size:	185.3 KB ID:	320773
    This are the "instructions" how to build this plane
    Click image for larger version  Name:	IMG_1615.JPG Views:	0 Size:	141.0 KB ID:	320774
    Click image for larger version  Name:	IMG_1616.JPG Views:	0 Size:	179.7 KB ID:	320775
    Part One
    Mounting base for the motor and power system
    In the instructions you will find 2x part "j", but there are 4x "j", so don't forget the other two 😏
ID:	320789Click image for larger version
ID:	320790Click image for larger version
ID:	320791Click image for larger version
ID:	320792Click image for larger version
ID:	320788Click image for larger version
ID:	320786Click image for larger version
ID:	320793Click image for larger version
ID:	320787Click image for larger version
ID:	320794Click image for larger version
ID:	320785Click image for larger version
      Part two
      Assemble the fuselage
ID:	320806Click image for larger version
ID:	320807Click image for larger version
ID:	320805Click image for larger version
ID:	320800Click image for larger version
ID:	320799Click image for larger version
ID:	320797Click image for larger version
ID:	320804Click image for larger version
ID:	320801Click image for larger version
ID:	320803Click image for larger version
ID:	320802Click image for larger version
        Part three
        Assemble the cowling
        It's much easier to soak the balso parts for a few minutes only into water (only one side needs to be wet) and then glue it. The "wet" side is outside, so the glue can dry without water.
        After it has dried, sand it carefully and remove the helping structure inside.
        The mini magnets will hold the nose in place
        (careful when glueing these magnets......they have a north and south pole)
        Click image for larger version  Name:	IMG_1276.jpg Views:	0 Size:	117.1 KB ID:	320809
ID:	320814Click image for larger version  Name:	IMG_1281.jpg Views:	0 Size:	113.4 KB ID:	320812Click image for larger version  Name:	IMG_1282.jpg Views:	0 Size:	140.4 KB ID:	320811Click image for larger version  Name:	IMG_1283.jpg Views:	0 Size:	111.7 KB ID:	320810
          Part four
          Assemble the landing gear
ID:	320818Click image for larger version
ID:	320816Click image for larger version
            Part five
            Assemble the upper and lower wing
            (Don't fix them onto the plane now, only the middle part of the upper wing is glue the the structure)
ID:	320823Click image for larger version
ID:	320824Click image for larger version
ID:	320821Click image for larger version
              Part six
              Assemble elevator and rudder
              (Glue first the paper hinge to the rudder and elevator and then cut them into pieces)
              Click image for larger version  Name:	IMG_1288.jpg Views:	0 Size:	88.9 KB ID:	320827Click image for larger version  Name:	IMG_1289.jpg Views:	0 Size:	109.9 KB ID:	320826Click image for larger version  Name:	IMG_1290.jpg Views:	0 Size:	137.4 KB ID:	320829 Click image for larger version
                Part seven
                Install the motor and power system
                (the whole elctronic will be connected as in this drawing)
                The motor mount screws will NOT fitc, I have grind the holes into "ovals" (to the middle), then the 3 screws will match the holes in the wooden motor plate.
                Also there are 2 smalls black screws, which will holds the motor itself, they are a bit outside. To avoid some wrong angles I have simple cut a piece of balsa as a "buffer" between motor and mount. Maybe its not helpful, but it feels better 😅
                Click image for larger version  Name:	IMG_1292.jpg Views:	0 Size:	106.9 KB ID:	320833Click image for larger version  Name:	IMG_1293.jpg Views:	0 Size:	80.9 KB ID:	320842Click image for larger version  Name:	IMG_1294.jpg Views:	0 Size:	85.4 KB ID:	320837Click image for larger version  Name:	IMG_1295.jpg Views:	0 Size:	82.6 KB ID:	320834
                Click image for larger version  Name:	IMG_1313.jpg Views:	0 Size:	87.7 KB ID:	320839Click image for larger version  Name:	IMG_1314.jpg Views:	0 Size:	55.8 KB ID:	320835Click image for larger version  Name:	IMG_1315.jpg Views:	0 Size:	73.3 KB ID:	320836Click image for larger version  Name:	IMG_1316.jpg Views:	0 Size:	70.0 KB ID:	320838Click image for larger version  Name:	IMG_1317.jpg Views:	0 Size:	99.4 KB ID:	320841Click image for larger version  Name:	IMG_1319.jpg Views:	0 Size:	106.0 KB ID:	320840
                  Part eight
                  Install the wings
ID:	320845Click image for larger version
ID:	320846Click image for larger version
                    Part nine
                    finals
                    The rods for the rudder and elevator I have "crossed". Otherwise they will be bend and pressend into the fuselage (poor servo)
                    Click image for larger version  Name:	IMG_1624.JPG Views:	0 Size:	62.7 KB ID:	320851
                    There is no Vickers MG in this kit. And without the Sopwith looks "naked". So I printed one in 3D and put it on top the fuselage
                    Click image for larger version  Name:	IMG_1622.JPG Views:	0 Size:	93.0 KB ID:	320850
                    And decals are missing. They are also printed
                    Click image for larger version  Name:	1627723313728631.jpg Views:	0 Size:	129.1 KB ID:	320849
                    How to find out the GC (the instructions says 10 - 15mm from the front edge of the LOWER wing)
                    Click image for larger version  Name:	IMG_1617.JPG Views:	0 Size:	41.5 KB ID:	320855
                    And last: I have sprayed the orange propeller black (looks nicer)
                    Click image for larger version  Name:	IMG_1619.JPG Views:	0 Size:	158.2 KB ID:	320852
                    All needed weights are in the nose.
                    Click image for larger version  Name:	IMG_1620.JPG Views:	0 Size:	161.4 KB ID:	320853Click image for larger version  Name:	IMG_1623.JPG Views:	0 Size:	128.9 KB ID:	320854
                    Thats all
                    Picture from flight will follow soon (at the moment, its heavy rain outside here in Singapore)
                    • #11
                      Thanks for posting your build log, I look forward to seeing your maiden report!
                      I built one of these a few years ago. It had a DSM2 5-in-1 as the MFCB. It flew alright, although the wheels gave me problems until I replaced them with wheels I cut from plasticard. Overall though, it was a fun build and rewarding to finally get into the air. I eventually cracked the firewall when it fell off my workbench.
                      The rudder is very small, btw. For more effectiveness, clear plastic packaging worked well.
                      • #12
ID:	352397 we made a one inch taller rudder on the dancing wings 1200mm camel it would not fly well enough at slow speed to get a nice three pointer landing this vid is with the small stock rudder the pic is of the old and new bigger rudder and it works alot better now
                        Dancing Wings Sopwith Camel Maiden Flights - YouTubeClick image for larger version
