PA-22 Tri-Pacer 1620mm (63") Wingspan - ARF from Nexa - NXA1027-001
The PA-22 Tri-Pacer is a light strut-braced high-wing monoplane aircraft built by Piper Aircraft from 1949 to 1964.
The Nexa PA-22 Tri-Pacer is a electric or gas option .60-size civil airplane with a 1620mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, fully functional flaps, fiberglass cowl, wingtip tanks and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this fun civil flyer!
Fully Covered The Nexa PA-22 Tri-Pacer comes fully covered in an attractive and sporty red and white scheme. |
Scale Details Throughout There is no shortage of scale details with this PA-22 Tri-Pacer including functional flaps, painted canopy and antenna. |
Fiberglass Cowling The cowl is made of fiberglass for both looks and durability. |
Slow Trainer or Aerobatic Charmer The PA-22 Tri-Pacer can both fly slow and easy with trainer-like dependability and stability while also performing aerobatics with ease and style. |
- Complete Balsa and lite-ply construction for rigidity and durability
- Covered from tip to tail in scale details including functional flaps, plastic seat, antenna, printed simulated panel lines and rivets
- Fiberglass cowling for strength and durability
- All control surfaces come out of the box pre-hinged and installed for convenience
- Large battery hatch allows for your chosen electric or gas setup
- Nexa PA-22 Tri-Pacer 1620mm (63") Wingspan - ARF
- Wheels and spinner
- Fuel tank, hardware and decals
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 400Kv or equivalent brushless outrunner motor - we recommend the Admiral GP10 5030-400Kv Brushless Motor
- 60 Amp brushless ESC - we recommend the ZTW Mantis 65A ESC with 5A SBEC
- 4x standard servos for ailerons and flaps - we recommend Hitec HS-85BB High Torque Micro Servo Airplane Multi-Pack (4 Servos)
- 2x standard servos for rudder and elevator - we recommend Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servo Airplane Multi-Pack (2 Servos)
- 4 Cell 14.8V 4500 - 5000mAh LiPo Battery - we recommend the Admiral Pro 5000mAh 4S 14.8V 60C LiPo Battery with EC5 Connector
- Standard 11x8 2-blade electric propeller - we recommend the APC 11x8 Thin Electric Propeller - Black
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
- .46 - .70 (7.45cc - 11.5cc) gas engine
- Standard 12x6 2-blade gas propeller
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :5+ hours
| Model Scale | 1/5 |
| Wingspan | 1620mm / 63.7in |
| Length | 1209mm / 47.6in |
| Empty Weight | 2900g / 102.29oz |
| CG (Center of Gravity) | 65-68mm from the leading edge of the wing's root |
| Power System | 400Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required) |
| Electronic Speed Control | 60-65A (required) |
| Propeller / EDF | 11x8 2-blade for electric or 12x6 2-blade for gas (required) |
| Servos | 45g metal gear standard: left aileron, right aileron, elevator, rudder 17g metal gear standard: left flap , right flap |
| Landing Gear | Aluminum gear (included) |
| Required Battery | 4 Cell 14.8V 4500 - 5000mAh LiPo Battery (required) |
| Required Radio | 6+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | No |
| Hinge Type | CA fabric |
| Material | Balsa and light plywood |
| Skill Level | Intermediate |
| Build Time | 5+ Hours |
