The XK Model J3 RTF is a great introductory model aircraft for beginners due to its built-in stability system (3D/6G) that supports smooth flights and resistance to crashes. A great park flyer with a removable wing and micro class size for easy transportation to and from the flying field.
The powerful brushless motor supports a wide flight envelope for flying everything from slow flight to impressive aerobatics. The XK Model J3 boasts attractive scale looks in the iconic yellow color scheme. If you are looking to get into the hobby with a smaller park flyer with a built-in gyro for stability and nice scale looks the XK Model J3 would be a terrific choice.
Features:
- Comes with 3D/6G, a gyro for increased stability and helps decrease the chance of a crash. Simply cycle between 6G (stable mode) and 3D (no control surface limits) by pressing the aileron stick to the lower left after activating the model
- Compact size and nice scale looks appeals to both novice and advanced pilots
- Powerful brushless motor supports a wide flight envelope from slow to aerobatic flight
- Removable wing with carbon supports for ease of transportation to and from the flying field
- Extended flight times (10-15 minute averages)
- XK Model J3 with Gyro 650mm (25.5") Wingspan - RTF
- FTR Futaba S-FHSS Compatible 4CH 2.4GHz Transmitter
- 2.4GHz Receiver
- 2S 7.4V 500mAh LiPo Battery
- 2S LiPo Battery Charger
- USB Charging Cable
- Replacement Propeller
- Owner's Manual
- Four (4) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying!
Product Specifications:
AGE LEVEL: 14 and up
SKILL LEVEL: Beginner
BUILD TIME: 1 hour
| Wingspan | 650mm / 25.5in |
| Length | 460mm / 18.1in |
| Flying Weight | 145g / 5.11oz |
| CG (Center of Gravity) | Refer to the manual |
| Power System | 1404 Brushless Outrunner Motor |
| Electronic Speed Control | Integrated |
| Propeller / EDF | 2-Blade Prop |
| Servos | Micro |
| Landing Gear | Fixed |
| Battery | 2S 7.4V 500mAh 25C LiPo (included) |
| Radio | FTR Futaba S-FHSS Compatible 4CH 2.4GHz Transmitter (included) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Foam |
| Material | EPP Foam |
| Skill Level | Beginner |
| Build Time | 1 hour |
| Recommended Environment | Outdoor |
