The North American Aviation T-28 Trojan is a radial-engine military trainer aircraft manufactured by North American Aviation and used by the United States Air Force and United States Navy beginning in the 1950s. Besides its use as a trainer, the T-28 was successfully employed as a counter-insurgency aircraft, primarily during the Vietnam War. It has continued in civilian use as an aerobatics and warbird performer.
This recently developed Nexa T-28 Trojan is now accessible to hobbyists, featuring a large interior hatch to enable convenient access with either electric or gas power. Incredible scale details, including a functioning pilot door, make the T-28 Trojan an optimal selection in any hangar.
Features:
- Complete Balsa and lite-ply construction for rigidity and durability
- Covered from tip to tail in scale details
- Large battery hatch allows for your chosen electric or gas setup
- Nexa T-28 Trojan Red and White 1770mm (69") Wingspan - ARF
- Landing gear and wheels
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- Brushless outrunner motor - we recommend the Admiral GP20 6320-295Kv Brushless Motor
- 70 Amp brushless ESC - we recommend the ZTW Gecko 120A ESC OPTO High Voltage
- 6x 45g standard metal gear servos for ailerons, nose gear, elevator, rudder, left and right elevator - we recommend Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servo Airplane Multi-Pack (6 Servos)
- 4x 17g standard servos for flaps and gear doors - we recommend Hitec HS-81 Micro Servo Airplane Multi-Pack (4 Servos)
- 6 Cell 22.2V 5000-6000 mAh LiPo Battery - we recommend the Admiral 5000mAh 6S 22.2V 50C LiPo Battery with EC5 Connector
- Electric propeller - we recommend the APC 16x10 Thin Electric Propeller
- 2-stroke engine - we recommend the NGH GT17-Pro 17cc Two-Stroke Engine
- 2-blade gas propeller - we recommend the APC 14x8 Gas Propeller
- Silicone fuel tube
- Electric retractable tri gear with struts (not included) - NXA1506-118
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
Product Specifications:
AGE LEVEL : 14 and up
SKILL LEVEL : Intermediate
BUILD TIME : 6+ Hours
| Model Scale | 1/7 |
| Wingspan | 1770mm / 69in |
| Length | 1350mm / 53.1in |
| Weight | 5500g / 194oz |
| CG (Center of Gravity) | 126mm from the leading edge of the wing's root |
| Power System | 295Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required) |
| Electronic Speed Control | 120A (required) |
| Propeller / EDF | 16x10 2-blade for electric or 14x8 2-blade for gas (required) |
| Servos |
| Landing Gear | Fixed (included) |
| Required Battery | 6 Cell 22.2V 5000 - 6000mAh LiPo Battery (required) |
| Required Radio | 8+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | No |
| Hinge Type | Nylon |
| Material | Balsa and light plywood |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
