Dynam F4U Corsair EXPO and RATES help!
  • Shywolf
    • Dec 2015
    • 10
    Need some help with the EXPO and Rates, anyone got any suggestions? Stock Dynam F4U set up with stock throws, no expo, but have low rate and high rate. What % expo should i use? was trained on bone stock 4 channel 20 yrs ago i know its small stick movements but have never flown with expo and getting ready to get back in hobby i taxi test yesterday and got off the ground a little but brought it back down wanted to fly/veer to the left hit the grass on side of runway flipped and snapped the rudder off clean break at the hinge point and bent the landing gear a little on one side lol i was lucky i guess.
  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    I run 30% expo on everything I have.
    • Shywolf
      • Dec 2015
      • 10
      Thanks dk i will try that, do you fly on low rates? I want to scale fly for now but im worried i will get in trouble and not have full throws.
      • jobinseattle
        • 281
        For what it is worth. For me there is no magic number as every plane is different. I usually dial down the travel on ailerons and elevator and set expo 60% or 65% on every plane. If it is too much I land and adjust. What works for me and I mostly fly in low rates.
        My YouTube Channel
        • dkalwishky
          Warbird Lover
          • Sep 2015
          • 1382
          • Des Moines, IA
          I don't normally fly on low rates. I guess the exception is my Ugly Stick, I've got a setting between low and high that I use.
